Author: Subject: zzr1100 c and d?
teegray19
posted on 16/8/11 at 05:33 PM Reply With Quote
zzr1100 c and d?
anybody know the difference between the zzr1100 pre 1992 cdi and the 1993 onwards d model cdi units? do they inter change?
help cheers.
minitici
posted on 16/8/11 at 06:04 PM Reply With Quote
C model used an dished offset gearbox sprocket and D model had a flat sprocket.
Can't remember but I think the overall sprocket position was the same as the output shafts were slightly different to compensate.
Other than that they were phsically the same.
Guinness
posted on 16/8/11 at 06:38 PM Reply With Quote
As far as I know the connectors are different.
Not sure about the gubbins inside. Never tried installing a D CDi on my C loom.
I can tell you that a C CDi will run both engines though!
spiderman01980
posted on 16/8/11 at 07:28 PM Reply With Quote
all i can tell you is that the colours on the wiring of the cdi are different colours, and d1-2 is a different wiring loom to d3-4-5, i got the haynes manual if you need a pic!
teegray19
posted on 17/8/11 at 11:07 AM Reply With Quote
thanks for the help, a picture wouldnt go a miss!
im thinking of a turbo zzr1100 so i may have to retard the timing with a piggyback ecu anyways.
as long as it got me going, if anyone has tried this let me know, be intereseted to see what the reslut was.
spiderman01980
posted on 17/8/11 at 02:16 PM Reply With Quote
give us your email address and ill scan them and send them to you!
teegray19
posted on 17/8/11 at 03:20 PM Reply With Quote
antonygray93@gmail.co.uk
spiderman01980
posted on 18/8/11 at 05:40 PM Reply With Quote
still not doing it! you got different email?
teegray19
posted on 18/8/11 at 07:41 PM Reply With Quote
its .com im an idiot, getting mixed up with my work email.
thanks mate.
