Author: Subject: Ohhhhh Blast it.
jollygreengiant
posted on 21/8/11 at 01:46 PM Reply With Quote
Ohhhhh Blast it.
Or words to that effect.
On the way to the Stoneliegh show, I found that I had a throttle problem. When I got home I found that a small piece of plastic from my induction set up had broken of and was jamming the butterfly open, intermitently. So I repaired the induction tubing and thought, Sorted.
A couple of weeks ago I went out on a blat round my area before supposedly going on a Fish 'N' Chip run to sunny hunny. However on my run out I found that I was having dificulty selecting 1st and 3rd. So I puulled out of the run. Oh and on the way home from my blat, I lost my air filter (as I ran over it and mangled it).
Anyway, today, I FINALLY got the car up in the air to inspect what was going on, because, other than the gearstick having moved sideways and forward by about 5mm, there was no obvious sign of anything.
Turns out that the nearside engine mounting, onto the block, has cracked on the underside between the plate and the shaft down. The offside mounting plate to the rubber insulater has distorted.
So, I now have to remove both the engine mountings and remanufacture them, using heavier plate. I thought that 3mm would have been enough, but, obviously the power from my pinto is too much and maybe I shall have to go for 5mm or 6mm.
Then I will have to remake the air filter housing again and by a new filter.
Bugg£r.
View User's Profile View All Posts By User U2U Member   jollygreengiant 's Aim This User Has MSN Messenger
Richard Quinn
posted on 21/8/11 at 02:59 PM Reply With Quote
It might be the weight rather than the power
posted on 21/8/11 at 03:13 PM Reply With Quote
3mm is certainly too thin for the typical design of engine mount used in the locost because it concentrates a lot of stress in a small area, and obviously there are significant cyclic loads which all adds up to fatigue cracks.
A 5 or 6mm plate would be much better, as would modifying the design to minimise bending forces on the plate.
posted on 21/8/11 at 03:44 PM Reply With Quote
Oh, you bitch! But I think you hit the nail on the head.
3mm does seem a bit on the thin side Clive but at least you have a pattern
stevegough
posted on 21/8/11 at 03:48 PM Reply With Quote
Yes, Clive and in the immortal words of Darth Vader......" DO NOT UNDERESTIMATE THE POWER OF THE ...ER ...PINTO "
Luego Locost C20XE.
IVA passed Jan 28th 2011.
First drive Feb 10th 2011.
First PASA mad drive 26/7/11
View User's Profile E-Mail User View All Posts By User U2U Member   stevegough 's Aim
ashg
posted on 21/8/11 at 07:50 PM Reply With Quote
3mm geez that is thin. i used 10mm plate for the engine mounts on the new engine
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Volvorsport
posted on 21/8/11 at 09:12 PM Reply With Quote
well since your engine mounts dont follow the oe design , there will be a roll couple from the engine , thats adding to the original weight of the engine during cornering/braking /accelerating .
engine mounts (the flexible bit ) should be placed in the plane of the centre of mass . or just completely over engineer them.
www.dbsmotorsport.co.uk
getting dirty under a bus
View User's Profile Visit User's Homepage View All Posts By User U2U Member   Volvorsport 's Aim
wilkingj
posted on 22/8/11 at 06:53 AM Reply With Quote
I made engine mounts from 3mm... and then had to make some new ones later on as the engine sagged, due to the mounts bending.
Havent moves now in 4 years!
Best Regards
Geoff
http://www.v8viento.co.uk
Irony
posted on 22/8/11 at 07:22 AM Reply With Quote
I bought new engine mounts from Luego. I beefed the 5mm steel plate up with some extra padding. There are some great ideas for engine mounts on this site however.
