Author: Subject: rear hubs
typ17
posted on 27/8/11 at 10:45 PM Reply With Quote
rear hubs
Hi guys,
Problably I am thinking to much about this and as so, i'm complicating things.
Anyway, my question is, when you thigthen the nut on the driveshaf to the specified torque it will push the driveshaft towards the outside of the car and push the inside bearing to it's correct place. correct?
I'm asking this becauseI just assembled the rear uprights and when placing the splined bit in( dont know the name but the part where the driveshaft will eventually go in to), using a hammer, it felt like the whole thing just went out of place....
Hope I am making any sense.
Thanks for the help.
mad-butcher
posted on 28/8/11 at 07:13 AM Reply With Quote
Photo might help
tony
typ17
posted on 28/8/11 at 11:37 AM Reply With Quote
Ive placed them in my archive.
and without, just bearings
and
with the splined bit in
Can you spot the difference from the dist caps as a start point.
mad-butcher
posted on 28/8/11 at 12:03 PM Reply With Quote
Hub part on my spare ones appear to go in further, may be when you put the other half in it will pull the hub further onto the bearings
[img] rear hub
rear hub
[/img]
tony
typ17
posted on 28/8/11 at 12:29 PM Reply With Quote
It does seem further in.
when you say other half what do you mean? the driveshaft?
mad-butcher
posted on 28/8/11 at 01:11 PM Reply With Quote
yep, the splined bit that the nut goes on, just make sure you don't put the wrong one on the wrong side, one is l/h the other is r/h, sorry can't remember which way is which. I think it's l/h thread on left, which would mean it would want to tighten with the rotation of the wheel same with r/h thread on right it would want to tighten.
tony
typ17
posted on 28/8/11 at 04:01 PM Reply With Quote
OK thanks for the help.
I will try to get more pics as I get on.
