New Topic New Reply
Author: Subject: how low does yours hang????
chicade
posted on 28/8/11 at 11:20 PM Reply With Quote
hi guys just wondered got a mk indy with R1 5pw engine how far past bottom chassis rail does the sump hang normally????
Coopz
posted on 29/8/11 at 07:35 AM Reply With Quote
Quite a lot, would have to measure. i think i'm 75mm from the ground i might be wrong still early for a day off!
dhutch
posted on 29/8/11 at 08:08 AM Reply With Quote
My sump as standard is about 2inchs past the chassis, giving a ground clearance of around 2 inchs to the sump. Thats on a ford CVH with a pressed steel sump.
- Hit a few bumps (it does happen, and i do drive it just about anywhere) and i moved the bottom up nearly an inch.
- Fitted a cut and shut short-sump from a freinds cvhand its about inline with the chassis, but i have no oil capicity and the big ends hit it.
Daniel
martynrich67
posted on 5/9/11 at 08:50 AM Reply With Quote
Mine has alloy spacers under the engine subframe mounts and it raises the engine by about an inch or so.
I think my sump sits about 30mm below the floorpan.
New Topic New Reply
