Nitrogeno25
posted on 1/9/11 at 04:44 PM |
Duratec oil filter
I found this oil filters suitable for the Duratec:
http://www.burtonpower.com/pr6719.html
http://www.burtonpower.com/1250507.html
Does anybody uses any of this filters, can you recommend which one?
Thank you very much!
DIYMAN
posted on 1/9/11 at 05:10 PM |
Oil Filter
I am using the Raceline oil filter adapter, which fits the oil filter at right angles to the engine. This uses the Ford EFL90 filter which is readily
available.
Nitrogeno25
posted on 1/9/11 at 10:41 PM |
available.
I'm also using this adapter. I will try to find the EFL90 then..
Nitrogeno25
posted on 2/9/11 at 01:53 PM |
available.
I found the EFL90 width is 96mm, that will foul the oil pressure sender on the raceline adapter??
Tiger Super Six
posted on 2/9/11 at 09:56 PM |
Raceline sent me one from halfords, part no HOF200
Mark
Tiger Avon
pjay
posted on 5/9/11 at 07:59 AM |
I'm using Halfords HOF203 on a Raceline adapter (as recommended by Chris at Raceline...)
Mark - keep meaning to compare the HOF200 and 203 to see which is shorter.
