Author: Subject: Ford X/Flow parts (Caterham)
Rusty Bolthole
posted on 8/9/11 at 09:22 PM Reply With Quote
Starter Motor - almost new (400 miles tops!) - £50
Water pump - fairly new - £20
Thermostat housing and pressure cap £10
Dry sump parts:
Mocal 10 row Oil Cooler and mounting brackets - £30
Mocal sandwich plate (oil filter take off) - £10
Mocal Dry Sump Oil Tank - easyclean, 6 L - £70
Mocal oil pump £30
Engine mounts (for dry sump car) £20
1 Caterham Clutch Cable unused - £20
1 Caterham Clutch cable used - good condition - £10
Uprated AP Racing clutch cover (see Burton Power website) correct curly finger type- £60 (I send it with the AP Racing uprated clutch plate which has plenty of use left in it)
http://www.burtonpower.com/parts-by-fitment-type/parts-by-engine-ford/ford-cross-flow-kent.html?brand=54&product_area=600&product_group=225 />
New, unused clutch release bearing - £10
Clutch release fork £10 to fit standard ford bellhousing
Bellhousing to engine gasket and dirt shield (2 piece) - £10
Unique, modified front timing cover (allows cam timing to be easily adjusted via inspection plate) - must have for racer! - £30
Is this a TRADE ADVERTISEMENT?? Click
HERE to report it!
martin62
posted on 8/9/11 at 09:30 PM Reply With Quote
thermostat housing
u to u
JacksAvon
posted on 8/9/11 at 10:49 PM Reply With Quote
u2u sent re timing cover
Trollyjack
posted on 9/9/11 at 02:15 PM Reply With Quote
2nd dibs on thermostat cover & cap
send me a u2u if still available
TrollyJack
