Author: Subject: Zetec coolant plumbing - ally tube with two tees needed.
adrianreeve
posted on 28/9/11 at 08:45 PM Reply With Quote
Hi there, I'm just plumbing my zetec in. For the bottom hose connections, I need a 32mm tube, with 2 15mm tees coming off it, one for top thermostat connection, one for expansion bottle. Does anyone have one, know where I can get one, or is able to make me one? As the Zetec is such a popular installation, I'm sure it must be a commonly used / made part!
Adrian
gdp66
posted on 28/9/11 at 09:06 PM Reply With Quote
from tiger
http://www.tigerracing.com/zencart/index.php?main_page=product_info&cPath=34&products_id=88
russbost
posted on 28/9/11 at 09:11 PM Reply With Quote
Take a look here at my recent post - I am definitely getting the bending & beading equipment & have solved the issue of being able to weld in suitable tees etc. Unfortunately it will take a week or 2 to get set up then I'm on hols for a couple of weeks, but if you can hang on till start of Nov I should be able to help. If thats a straight pipe with tees, I doubt it would come to more than £20.
Please let me know if of interest.
skidmark
The plastic water rail off the side of a C20XE engine has 2 x 15mm ish tees and approx 32mm at each end if you cut it down and do a bit of fettling. That's what I used and seems to be working well.
russbost
posted on 28/9/11 at 09:13 PM Reply With Quote
Danger with cutting it down is you then have no beads to keep the hose on with - that could get very expensive!!!
skidmark
posted on 28/9/11 at 09:24 PM Reply With Quote
Yes, a beaded joiner iss obviously better and ife can be done for £20 then that sounds like the best way forwards. I haven't had any problems for over 2000 miles and a trackday though.
scutter
posted on 28/9/11 at 09:29 PM Reply With Quote
Adrian, why not use the ford part?
ATB Dan.
adrianreeve
posted on 28/9/11 at 09:39 PM Reply With Quote
Dan
What ford part?
Russ, sounds good, may well take you up on that!
Adrian
big_wasa
posted on 29/9/11 at 07:23 AM Reply With Quote
The ford part is the spider hose and no use due to size and it being to complex.
Norfolkluegojnr
posted on 29/9/11 at 09:30 AM Reply With Quote
CBS do cheap T pieces.
I used the plastic as opposed to ally, but 400 miles in, no leaks and all is well.
Linky
lewis
posted on 3/11/11 at 08:23 AM Reply With Quote
im also on the lookout for the same item,russbost i have sent you a u2u your solution would be the cleanest design
I am a driving god!..........sort of
