Author: Subject: Does anyone know what diff would fit in a vauxhall viva axle as i would like to change the gear ratio, Eg Morris, Mg?
rich201283
posted on 30/9/11 at 06:04 AM Reply With Quote
AndyGT
posted on 30/9/11 at 08:01 AM Reply With Quote
Chevette cwp?
AndyGT
posted on 30/9/11 at 08:02 AM Reply With Quote
What ratio do you have now?
From interest, do you want to go higher or lower than standard?
nothing is impossible
everything is possible
rich201283
posted on 30/9/11 at 10:14 AM Reply With Quote
I belive the diff is 4.125:1 - i want a lower ratio as it revs a buit high when cruising
r1_pete
posted on 30/9/11 at 11:24 AM Reply With Quote
The 1.6 Viva was 3.9 IIRC the 1.8 & 2.3 Firenza &Magnum were higher too
bmseven
posted on 30/9/11 at 05:26 PM Reply With Quote
There was a Magnum axle up for grabs the other day? Cant remember where JPSC?
BMW 7 Resource
Bures Pit anyone?
posted on 30/9/11 at 06:42 PM Reply With Quote
You mean a higher diff ratio not lower for less revs at a given speed . the numbers may be lower but the ratio is higher. A five speed box would give less revs for a given speed but it would depend upon which engine you have as to if one is a straight fit . If you are using a Viva engine I don't know of any
