beaver34
| posted on 5/11/11 at 06:14 PM |
turbo return
people who have made a turbo return line,
what did you make it from? mine will have to run through the manifold to the sump i have a normal flanged fitting with a 19mm stub on it, can i just
run a braided line down what temps can braided oil line withstand?
Simon
| posted on 5/11/11 at 08:53 PM |
I made an exit tube from the turbo (only about 3" long) from scrap steel tube welded to a homemade flange to bolt to turbo drain, then used a
bit of rubber hose to connect to another bit of steel tube welded to the sump.
HTH
Simon
matt_gsxr
| posted on 6/11/11 at 08:58 AM |
I have a 3inch pre-built outlet in steel (fairly wide bore) and then pipe it with rubber oil hose to the sump.
The first bit is quite close to the hot bit of the turbo on mine.
Rob Allison
| posted on 13/11/11 at 04:37 PM |
Yes you can use a braided line. But if its passing the exhaust manifold then its worth fitting a heat shield wrap over it or the manifold
C1 14inch Turbo Oil Drain Teflon Line KKK K03 K04 T517Z | eBay
