New Topic New Reply
Author: Subject: roll bar back stay possitioning
luke
posted on 13/11/11 at 10:34 PM Reply With Quote
Hi all,
Is there any limitations on how far inwards the bottom of the roll bar back stays can go? I dont want to weld them in and then find i cant fit the tank between them later on.
Any pictures or dimensions would be helpful.
Luke
Ben_Copeland
posted on 14/11/11 at 07:28 AM Reply With Quote
Mine come down at an angle into the bottom corners of the rear most chassis.
Tank went in ok with no back panel fitted. Would of been a bit of a struggle with panel on!
Ben
Locost Map on Google Maps
Enter Your Details Here
Daddylonglegs
posted on 14/11/11 at 08:19 AM Reply With Quote
This is how I did mine. I used a Spitfire fuel tank, and managed to get it in/out after I had fitted the rear panel.
minitici
posted on 14/11/11 at 10:57 AM Reply With Quote
If you need your roll over structure to comply with MSA regs (i.e. for competition) then the backstays have to make an angle of at least 30 degrees with the vertical.
Neville Jones
posted on 14/11/11 at 03:43 PM Reply With Quote
With a se7en type car, you'll struggle to get the 30degrees.
Just put the backstays as far back as is practical.
Nev.
luke
posted on 14/11/11 at 03:49 PM Reply With Quote
Thanks chaps, second question then is does anyone know a supplier of 44mm o/d 3mm thick tube? im not having much luck.
[Edited on 14/11/11 by luke]
procomp
posted on 15/11/11 at 12:29 PM Reply With Quote
Hi
Try looking for 45mm x 2.5mm ( MSA spec) rather than 3mm.
Cheers Matt
adithorp
posted on 15/11/11 at 01:06 PM Reply With Quote
might be worth a u2u to welderman (joe) to see if he's got any and he's not a million miles from you.
http://jpsc.org.uk/forum/
luke
posted on 15/11/11 at 02:45 PM Reply With Quote
Originally posted by procomp
Hi
Cheers Matt
cheers matt,
I had those dimensions off the material that ive had the roll bar made from (made by OPB). I want to add a second cross bar to attach the seatbelts to, and i read that it had to be the same dimension tubing as the rollbar for strength. However, i guess when welded at both ends theres no way the inspector will be able to tell the difference, especially such a small difference.
adithorp, Thanks i will try welderman.
Luke
New Topic New Reply
