steve m
posted on 14/11/11 at 08:11 PM |
2008 mondeo TDCI fuel economy
Hi
My Mondeo, 2008/TDCI used to be ultra ultra economic to drive, and according to the onboad computor
averaged, 40mpg,
Even towing, it was up in the high 30's
That was a year ago, and now i seem to be averaging around 30-33 mpg
and towing 28-30 ish
What seems to be the problem? and its not my right foot!!
It has been serviced, yet i do suspect the fuel filter was not done, only a hunch, but.........
The engine is also, on start up, like a tractor, very very noisy, yet next doors diesel VW taxi, with 330miles on the clock is nothing
as loud as My mondeo with 36,000
regards
pekwah1
posted on 14/11/11 at 08:14 PM |
yep filters and stuff would be a good thing to check.
also the MAF sensors seem to massively effect MPGs if they're screwed.....
BigLee
posted on 14/11/11 at 08:21 PM |
Clogged up EGR valve is a common problem. Also, if it was main dealer servicing, I would check to see if the air filter has actually been replaced.
The turbo pipe often splits which causes issues. Main dealer wouldn't notice as the computer can't diagnose it!
Oh, and check your tyre pressures. Sometimes its the simple things...!
steve m
posted on 14/11/11 at 08:29 PM |
This is my first ever diesel, so, were is the MAF and EGR ???????????
BigLee
posted on 14/11/11 at 08:40 PM |
Check the other things first. They're easier! My mate runs a 2.2tdci and his Exhaust Gas Recirculation valve was front left as you look with the
bonnet up. We blanked it off with a plate off eBay. His car has run perfectly since. Check YouTube for a tutorial.
steve m
posted on 14/11/11 at 09:00 PM |
Ive just bought a blanking plate off ebay
Now tell me the pit falls of fitting one!!!
steve m
posted on 14/11/11 at 09:02 PM |
Oh
Tyres were all about right, rear left was 1 psi down,
and the air filter is clean, but a halfrauds item,
and funny thing, im sure my economy dropped since, when i fitted it??
could be the problem?
steve
posted on 14/11/11 at 09:06 PM |
Steve,
What size engine is it? 1.8 or 2.0
40 mpg seems a little low to start with to me, I'd expect mid to high 40's.
posted on 14/11/11 at 09:08 PM |
I was often warned that blanking off can send you blind
steve m
posted on 14/11/11 at 09:11 PM |
its a 2.0, tdci
the trip computer used to say avereging 48mpg, but surely that cant be right!!
And i have never run any other fuel, than pump fuel, despite my nagging head that i should
AndyW
posted on 14/11/11 at 09:25 PM |
I used to have a 2.0 tdci and it sounded like a tractor from the day it was new, and sounded exactly the same when it had done 110k miles after 3
years. I was averaging 45+mpg but cant remember what it was averaging at the end.
MikeR
posted on 14/11/11 at 09:50 PM |
I'm watching this with interest. My old focus 2.0 tdci used to do low 50's on the motorway. Upgraded to an smax (which i appreciate is a
few hundred kg heavier and a larger frontal area) but i was disappointed to only get 44mpg on a motorway despite sticking to 70 or below and using
cruise.
AdrianH
posted on 14/11/11 at 10:03 PM |
My even older 2.0 TDDI Estate with 181,000 on the clock does around 44 mpg will get to 46-47 if I drive light footed and keep the speed within the
limits of the motorway.
I would try the MAF filter, but also just check none of the rubbers are blowing especially between the turbo and the intercooler.
If done your own service ensure you have used the correct grade oil.
And mine really does sound like a tractor, being the TDDI does not help neither does the conversion I did to solid flywheel after the old one started
to give way.
I would be expecting better mileage for the TDCI
Adrian
Why do I have to make the tools to finish the job? More time then money.
posted on 14/11/11 at 10:21 PM |
Strange how fast technology has moved there really, one of the volvo estates now gets over 70mpg. Bonkers compared to just a few years ago.
steve m
posted on 14/11/11 at 10:32 PM |
"I would try the MAF filter, but also just check none of the rubbers are blowing especially between the turbo and the intercooler. "
oooh, sounds coool (haha) ive got an intercooler, on my diesel, so were the fcuk is it !!
Ninehigh
posted on 15/11/11 at 05:38 AM |
Couldn't tell you but my one is getting about 42 now (missus drives it hard at times too, and it's nearly all town driving) after 100k..
and all the servicing it's had is oil changes.
I can look it up in my Haynes book if you wish, but mine's the 2005 model (if yours is the newer one it might be different)
snapper
posted on 15/11/11 at 06:22 AM |
Similar problem with my 53 plate TDCI would run 50 mpg on a run. Mid 40's to work now dropping to early 40's
Injectors leaking have bought special tools
Intercooler pipe split 3 months ago, the one from EGR.
Will clear out the EGR next.
I eat to survive
I drink to forget
Ben_Copeland
posted on 15/11/11 at 07:39 AM |
My 2.2 tdci regularly get 23mpg average but that's cos I'm using all of its 155bhp
It's done 40k and is quite happy to cruise at 45mpg at 75.
Lots of things could affect mpg, but it might be lots of little things that added together make big difference. Cleaning out pipes and throwing away
the halfords crap filter will help. Also check that when you put air filter in the air box lid is sealed down properly.
[Edited on 15/11/11 by Ben_Copeland]
Ben
Locost Map on Google Maps
Roadster
Enter Your Details Here
FASTdan
posted on 15/11/11 at 08:02 AM |
Gotta say now that its lights on time of year I'm only seeing 35mpg from my 2.2 ST TDCI. 46mpg on the motorway with cruise control set to err
70'ish lol.
Slightly concerned about mine - my journey is only 8 miles, lots of up and down hills and junctions so perhaps its to be expected? I do have a whistle
when on boost though so I suspect I have a split pipe somewhere?
NEW danST WEBSITE NOW LIVE! Bike carbs, throttle bodies and more......
http://www.danstengineering.co.uk/
sdh2903
posted on 15/11/11 at 09:09 AM |
Jesus, I was toying with the idea of swapping my st220 for an st tdci because I was sick of 25mpg dont think I will bother now!!
Back to the original topic, different engine but same principal, cleaned out the egr plenum on my dads s60 d5 at the weekend and couldnot beleive the
amount of gunk and crap that was in there and the engine still able to run. Afterwards the engine is so much quieter, smoother and giving around
5-10mpg better.
quinnj3
posted on 15/11/11 at 10:34 AM |
Hi Guys,
To me even early 40's mpg is wee poor for a modern 4 pot 2 litre diesel. As everyone says check the egr valves and MAFs. Make sure all pipes
are good and secure with no leaks etc.
Oh for comparison my 2003 318CI 1995cc 140bhp petrol does 38mpg comfortably with a light foot and no motorway driving, all terrible N.Ireland B roads.
brookie
posted on 15/11/11 at 06:57 PM |
i got an 2005 2.2 st mondeo and i get 40/41 mpg m8
