smart51
posted on 18/11/11 at 08:58 PM |
Recomend a printer please
My printer / scanner has stopped working and despite dismantling it and looking for broken bits, it is quite dead. So tomorrow I'll go and get
another. What do you recommend.
The one I had was an Epsom and I was quite pleased with it. Until it came to pay £40 for a box of ink cartridges. Kodak claim their printers are
cheaper on ink but are they any good?
What I need is a fast page-per-minute speed, the ability to print 6x4 photos onto glossy paper and a half decent scanner. Oh, and cheap ink! Any
suggestions?
Greenie
posted on 18/11/11 at 09:03 PM |
Kodak every time, 2 kids at Uni and got one for each of them, absolute top product........
blakep82
canon are always good, get one with seperate colour inks!
and don't get printer scanner fax all in one effort! no no no!
________________________
DixieTheKid
posted on 18/11/11 at 09:29 PM |
Top tip. The better quality the paper the less ink you will use. Cheap paper sucks up the ink.
COS IT'S Worth IT
posted on 18/11/11 at 09:38 PM |
mine doesnt do photos but i was staggered how fast it prints a page out when i first used it. Paper went through so fast i thought it hadnt printed
anything. It was only £40 at sainsburys, and its an HP.
Xtreme Kermit
posted on 18/11/11 at 09:43 PM |
Another vote for a kodak.
Reliable and cheap to run.
austin man
posted on 18/11/11 at 09:51 PM |
I have nothing but praise for the Cannon Pixmia I have the P4850 stunning picture quality also prints printable CD's. I also have an Epsom with
scanner was doubting the quality of print when printing to Kodak paper the photo quality was acceptable but nothing to write home about. Then I tried
epsom paper in it an the quality improved immensly.
TBH I was buying Epsom inks then started buying from the bay of e an appear to be as good as the epsom but probably 20% of the price
dave
posted on 18/11/11 at 09:54 PM |
Kodak
snapper
posted on 19/11/11 at 08:16 AM |
For photos
Epson + Epson paper
Kodak + Kodak paper
Etc
Lyson refillable external resoviour inks
Brilliant papers
But you need ICC profiles and the knowledge to instal them
I eat to survive
I drink to forget
snakebelly
posted on 19/11/11 at 08:28 AM |
Kodak all in ones, great quality and well priced consumables, check out your local currys.comet etc as a new range has just been rleased which means
they usually have some manager special end of lines going cheap.
iank
posted on 19/11/11 at 08:50 AM |
I bought a cheap Samsung laser printer for black and white and use photobox for printing photo's
Think this one has replaced it but I've not had a problem buying toner (which lasts ages compared to ink in my experience)
http://www.amazon.co.uk/Samsung-ML-1660-Printer-capacity-sheets/dp/B003D1TK4A
If printing photo's at home 6 colour printers make a much better job of it, but cost on the ink!
Anonymous
tonym
posted on 19/11/11 at 09:14 AM |
I always choose the ink cartridge first then the printer. This way you avoid expensive ink when you come to refill.
For cheap cartridges try Hornsea Inkjets on the Web
liam.mccaffrey
posted on 19/11/11 at 09:57 AM |
just replaced our workhorse witha kodak hero 5.1, 90 odd quid from tesco, very pleased and the consumables are very reasonable and I'm more than
happy with thing.
Build Blog
Build Photo Album
posted on 19/11/11 at 11:51 AM |
Juts bought a Canon Pixma MG6150 and can't praise it enough. It has a built in scanner so can be used for photo copying etc. the ink tanks are
all individually replaceable (and cheap third party ones are easily found) and the print head itself is easily replaceable. It also has Ethernet and
Wi-fi built in as well as USB, and a card reader to print direct from memory card. The paper also sits flat in a drawer under the printer, so
doesn't get curled up like a top-loader, and it does automatic duplex printing.
Print and scanning performance have so far been beyond reproach. I got it on special offer for about £70 at
Pixmania, though it seems to have gone up to £92 now.
I'd gladly have paid that for it though.
se7en
posted on 19/11/11 at 01:20 PM |
You are partially right, Dixie. The same amount of ink is delivered on either paper, it is the absorption rate that makes the print on good paper look
better than using the cheap high absorbing paper.
I previously always used Epson printers but now I use a Canon Pixma IP4600. It produces excellent print quality, better than that of any of my old
Epsons. I print on Fuji Photo Paper with non OEM replacement inks from 7-day Shop @ £7 for a full set. I also use a cheap laser printer for anything
Black & White; the toner is a lot cheaper per copy than the inkjet.
The cost of printing can be reduced by using your printer economically; do test prints using the Fast or Draft print settings and only when ready to
produce the quality output switch to the higher quality setting. I also use both sides of the paper when doing test prints. When printing photos,
before using the good Photo paper I do test prints on plain paper using the Fast or Draft settings.
HTH
Tom
russbost
posted on 19/11/11 at 01:33 PM |
I have both Epson stylus & Canon ip 4600, both have been great workhorses, they have done a lot of work!! I would only buy something which you can
buy non - original inks for, Epson/Canon price around £12 - £15 a cartridge, Ebay price for compatible inks (which I've had no probs with at
all) sometimes less than £1ea!!! Possibly not so good if you're printing photos, but personally if i want pictures printed I woukld always go to
a proper photo print place if quality is important.
smart51
posted on 19/11/11 at 06:48 PM |
Thanks everyone. I bought a Kodak in the end. The ink is half the price of the others. I've only printed in black so far but the quality is
brilliant.
