Author: Subject: Fit and Forget Fuel Tank... What's Required!?
posted on 21/11/11 at 05:16 PM Reply With Quote
Once I've put a tank into the rear compartment of my trike tub, the floor will get sealed... it will only ever be opened again in the event of a disaster!
I'll avoid an internal fuel pump and fuel level senders as I won't be able to get to them in the case of a malfunction. Similarly I won't be able to renew foam when it degrades, so it will have to either be baffled or have an internal collector... is one of these options better than the other?
Lastly, the floor of the trike will be an aluminium / honeycomb sandwich panel. Is there any reason why the tank couldn't be welded directly onto it?
Cheers!
PS - I have an inspection hatch at the rear of the tub where I can get a hand in to connect inlet / outlet hoses.
It's Evolution Baby!
Bare
posted on 21/11/11 at 05:45 PM Reply With Quote
Consider buying a Race spec Fuel cell?
SeaBass
posted on 21/11/11 at 06:05 PM Reply With Quote
Not a very good idea as most use a bladder to meet impact resistance requirements. Therefore they have a limited lifespan. I suggest you read more about them to extend your knowledge.
I would use a well designed and made alloy tank. Try to design the connections so they are outside your closed area. Eg no rubber fuel lines or clamps inside
posted on 21/11/11 at 07:23 PM Reply With Quote
Fitting a fuel tank into a seal enclosed space is risky --- it must be vented to let vapour out and air in or you run the risk of the space filing with vapour-air mixture in the explosive range --- then if the tank gets shunted the odds are it will go boom ! in a big way.
posted on 21/11/11 at 07:27 PM Reply With Quote
Sorry - should have been clearer... the inspection hatch I mentioned is open. You can see it on the rear bulkhead in this pic...
davidimurray
posted on 21/11/11 at 09:03 PM Reply With Quote
If your using an aluminimum honeycomb panel you will not be able to weld to it as your will destroy the glue bonding it together - the same applies around exhausts etc as the heat can damage the panels - I learnt the hard way!
If your using aluminium honeycomb why not machin up some 'tapered top hat type' adaptors to go through the panel and then have a tapped boss on the tank? We used to build aluminium honeycomb monocoques at uni and we used the top hats for all attachments including suspension mounts etc. We did loads of testing on designs and pull out strengths etc. Might have some pics/drawings around if they are any help.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
posted on 21/11/11 at 09:06 PM Reply With Quote
That makes perfect sense! Thanks for that David!
nz_climber
posted on 24/11/11 at 04:40 AM Reply With Quote
And the skin on alloy honey comb is usually less than .5mm good luck welding alloy that thin, plus what was mentioned above about it destroying the bonding agents.
http://aarons7.wordpress.com
