carlknight1982
| posted on 30/11/11 at 09:52 PM |
BMW v8 advice
Early 90's m60 3.0 engine. Was it ever mated to a manual box if so which one ?
Logic will get you from a A to B
Imagination will take you everywhere.
stevebubs
| posted on 1/12/11 at 12:19 AM |
Yes - I had one in my L Plate E34 530i touring...fantastic combination. don't know what the box was, though... but 3rd Gear was Awe ... wait for
it ... some...
[Edited on 1/12/11 by stevebubs]
dlatch
| posted on 1/12/11 at 01:13 AM |
whats wrong with a pinto carl
i think quite a few bmw manual boxes will bolt straight up
or even better get the M5 V8
[Edited on 1/12/11 by dlatch]
carlknight1982
| posted on 1/12/11 at 07:55 AM |
Fancy a v8 in roadster number 2
Chippy
| posted on 1/12/11 at 11:55 AM |
Yes so did I untill I did a bit of research on the BMW V8, and found that it is impossable to shorten the sump, something that would be almost certain
to be needed in a seven. The reason is that the oil pump is contained in the sump, and unless you go with a dry sump set up, (£1K Plus), then the sump
hangs down too far. HTH Ray
jossey
| posted on 1/12/11 at 12:17 PM |
why not get the m73 engine. its a lot better engine and much easier to get hold of given the range of BMW M~?'s it appears in.....
The BMW M73 is a V12 piston engine built in Munich, Germany. It has an Alusil aluminum engine block and aluminum SOHC cylinder heads. While most other
engines in the BMW had switched to four valves per cylinder, the M73 used 2-valve SOHC heads and featured fracture-split forged steel connecting
rods.
Models Engine Displacement Power Torque Redline Year
M73B54 5.4 L (5379 cc/328 in³) 240 kW (326 hp) @ 5000 490 N·m (361 ft·lbf) @ 3900 6000 1994
M73TUB54 240 kW (326 hp) @ 5000 490 N·m (361 ft·lbf) @ 3900 6000 1998
even better is the 530d e60 model engine which is twin turbo and weighs hardly anything. only issue is getting the engine out of the bimmer
David Johnson
rodgling
| posted on 1/12/11 at 12:54 PM |
If the sump is similar to the S50/M50/M52 (E36 M3 etc) engines then you can get about 10 cm clearance below the unmodified sump without going to a
silly ride height.
A dry sump would be nice, and I'll be keeping my eyes open for a cheap one, but it's certainly not essential.
Surely the M73 is massive and heavy?
stevebubs
| posted on 8/12/11 at 02:01 PM |
5 speed manual box - BMW e34 530i 540i V8 5 speed gearbox manual | eBay
6 speed manual box - 6 speed manual gearbox BMW V8 | eBay
[Edited on 8/12/11 by stevebubs]
rodgling
| posted on 8/12/11 at 02:25 PM |
The 5 speeds are thought to be much stronger (and lighter), at least on the 3- and 5- series.
