Author: Subject: Quaife diff
madteg
posted on 10/12/11 at 10:05 AM Reply With Quote
Quaife diff
Thinking of fitting a new diff, has anybody fitted a quaife unit to a 7" sierra diff housing. What sort of job is if and is there anything i should know. Like what sort of diff is best plate or the other sort that i cannot spell
Rob Allison
posted on 11/12/11 at 10:34 AM Reply With Quote
There not to hard to do if your just swaping centres. Undo side bearings, remove crown wheel from centre, fit to new one. Refit side bearings. setup backlash and load up bearings.
plated are best, £750 for one.
ATB are fit and forget. Nothing to wear out. £550
Viscus are the standard one. From either XR4x4 or a cosworth 4x4 . There ok and about £100 for a complete diff.
TimC
posted on 11/12/11 at 11:16 AM Reply With Quote
The ramp angles etc should be correctly set on a plate-type diff (Tran-x, Gripper etc) and the clutches do wear. I'd suggest that you get someone who really knows what they are doing to set-up a plate-type diff. Matt/Ivan at Procomp or Andy at Arrow Auto Engineering would be the forum-dwelling folk I'd ask.
The Quaife is a less involved job but I'm still getting Matt to fit mine to my English diff (fit the recommenced solid spacer, inspect/replace bearings etc.) That way, I know that it really will be fit'n'forget.
westy turbo
posted on 13/12/11 at 05:36 PM Reply With Quote
Ill guess the plated diff will last less but i guess has to do with torque and how often the next overhaul will be.
hobbsy
posted on 13/12/11 at 06:04 PM Reply With Quote
Only other downside of the Quaife ATB is that if one contact loses contact with the ground altogether then it acts like an open diff. Not normally a problem unless you really ride the kerbs on track.
I went for a Quaife and got Phil at Road and Race transmissions to fit it as it was a pain to remove my diff and didn't fancy doing it again if I messed up the fitting of the LSD.
Stott
posted on 13/12/11 at 07:56 PM Reply With Quote
Isn't the point of the atb to get the torque to the gripping wheel, so if you hop a wheel in the air than all the torque should go to the other wheel, it should never act like an open diff
hobbsy
posted on 13/12/11 at 08:11 PM Reply With Quote
No for it to work it needs to have *some* resistance on the other wheel, even if it's a very small amount, see here:
http://en.wikipedia.org/wiki/Limited_slip_differential
"In the case of slip, the wheel in contact can receive up to X times the torque applied to the wheel which is slipping, where X is the torque multiplication value for the differential. In this sense, torque sensitive differentials are not strictly limited slip - once an output shaft becomes free (e.g., one driven wheel lifts off the ground; or a summer tire comes over ice while another is on dry tarmac when the car goes uphill), no torque is transmitted to the second shaft and the torque-sensitive differential behaves like an open differential."
To be honest I've never found it an issue.
Stott
posted on 13/12/11 at 10:02 PM Reply With Quote
Every day's a school day!
Anyway, I'm gonna try it next time I'm out the garage, standby for either "quaife diffs do act like open diffs!" thread or "wanted - garage door" thread
snapper
posted on 13/12/11 at 10:50 PM Reply With Quote
I had a thought...........
You can get a valve that retains a little pressure to the calipers to stop the pads retracting when racing,
Just a few pounds pressure but should be enough to stop the ATB spinning free.
I eat to survive
I drink to forget
