r1_pete
posted on 15/12/11 at 09:47 PM |
Glass Fibre front end, opinions, experience?
Has anyone any experiance of Honeybourne Mouldings
I'm thinking of putting one of their front ends on my E Type, and wondered if anyone had any comment on their quality.
My options are limitted to rebuilding my own, which will cost me at least £1,000, plus prep and paint, replace the entire bonnet in Steel, about
£5,000, alloy nearer £7,000, or a GF one at £760.
How do you find glass fibre bodywork stands up in use?
Cheers.
Pete.
flak monkey
posted on 15/12/11 at 10:00 PM |
Should be fine. GRP is really easy to work with and pretty simple to repair. As long as its fairly thick to resist sagging under heat etc.
I have a complete GRP front end for the Camaro when I get around to putting it back together, wings, bonnet and bumper.
Sera
http://www.motosera.com
tegwin
posted on 15/12/11 at 10:08 PM |
Worth checking what exactly its made of... If its close to anything hot, ideally the grade of fibre/resin wants to be right.... Its also really hard
to stop the surface cracking... My TVR had a one peice hinged front section from the nose to the scuttle.... Recently re-sprayed ... but with a few
drives and unavoidable flexing in the panel, small spiderweb cracks could be seen in the new paintwork....... Maybe a fault in the paintjob.. I dont
know!
www.verticalhorizonsmedia.tv
posted on 15/12/11 at 10:11 PM |
The standard E-type bonnet ain't exactly light, it is also a swine to change and get the the catches lined up ---- if the one we repaired
is anything to go by I would guess your main problem will be rust at the hinges.
matt_gsxr
posted on 15/12/11 at 10:13 PM |
Don't know about e-type bonnets, but fury and phoenix have fibreglass bonnets. A bit of heat proofing on the underside can help near the
manifolds.
That site has some potentially useful power bulges.
http://www.honeybournemouldings.co.uk/fibreglasspowerbulges.htm
NigeEss
posted on 15/12/11 at 10:39 PM |
About 20 years ago ought a one piece flip front for a Mini from them. Was pleased with the
quality and it was strong enough to trash the rear quarter panel of a Nissan Stanza, It was
not too pretty afterwards though
Andybarbet
posted on 15/12/11 at 11:08 PM |
About 15 years ago i bought a fibreglass hardtop from them for my soft top TR7 (the triumph factory never made one for the tr7 drophead)
Quality was good & a great company to deal with back then, they must have been going 30 years now.
posted on 16/12/11 at 10:14 AM |
Cheers.
Pete.
Presumably the GF bonnet will also require prep and paint?
If so then repairing the original bonnet would seem the best approach in terms of value IMHO. A GF bonnet on an E-Type will surely have a negative
effect the car's overall value?
I've helped my Dad restore four E-Types now and the biggest headache is always fitting and aligning the bonnet. It's heavy, awkward to
handle, easily damaged and never straight
r1_pete
posted on 16/12/11 at 01:57 PM |
Thanks for all the replies chaps...
My existing bonnet isn't too bad, it just needs a new panel under the bumper, but I also fancied a Series 1 style with covered headlights.
Yes they are heavy, about 80-90kg I believe, and about a third of the cars bodywork.
I'm not too worried about resale values, I want a nice condition usable car, its far from standard anyway, so I'm afraid if the purists
don't like it they can look away, its not for sale anyway.
Guess I could always keep the steel unit in case circumstances change.
Cheers.
Pete.
Thinking about it
posted on 16/12/11 at 06:49 PM |
I bought some Midget wings about 30 years ok. No problems at the time.
