Author: Subject: Can bike carbs be separated?
Benzine
posted on 4/1/12 at 04:39 PM Reply With Quote
Reading the latest PPC mag the other day about bike carbs got me thinking. I've still not got my car sorted with megasquirt and if I switch to carbs I could keep my EDIS setup, sell megasquirt, sell wideband lambda kit & gauges and have plenty of cash to buy a megajolt unit and some bike carbs. Webers etc go for silly money, but if I can use bike carbs then that would be great.
In PPC it says for 2000cc engines 38-42mm carbs would suit. As bike carbs I've seen are in a row of 4 that's 1 carb per 500cc, as my straight six is 3000cc that's also 500cc per cylinder. I've not seen bike carbs, but can any be separated & spaced at all so I can get a row of 6?
Carbs listed in PPC that are 38-42mm are Honda Fireblade (CBR900RR/CBR919RR), Kawasaki ZZR600, Yamaha FZR1000, Suzuki GSXR750, Kawasaki ZX9 (ZX900 Ninja), Yamaha R1, Honda Blackbird. Could any of those be split? Or alternatively are there other bikes that use pairs so I could use 3 pairs?
[Edited on 4-1-2012 by Benzine]
hector
posted on 4/1/12 at 04:46 PM Reply With Quote
Yes they can be split, but to extend them you would have to probably machine a through hole for butterfly shaft AND possibly fuel channel. Tis feasible if you really wish to!
cheers Colin
jacko
posted on 4/1/12 at 05:03 PM Reply With Quote
Yes you can
You need two Set's of carbs then remove the too center carbs from one of the Set's so you have
end carb -center - center - center - center - end carb
http://www.boggbros.co.uk/gallery4.html
Have a look at Bogg Brothers web site
Jacko
clanger
posted on 4/1/12 at 05:18 PM Reply With Quote
found a link from Pejay's Tiger thread you might find useful?
http://www.sportingfords.com/forums/viewtopic.php?f=16&p=19574#p19007p19007
got a bit of bike TB overload myself at the mo.........thanks for the other bike info as i've been hunting GSXR bodies all over the planet
any additional info on what year bikes the alternative TB's are suitable?
whitestu
posted on 4/1/12 at 05:29 PM Reply With Quote
ZX6R carbs are 38mm and easy to seperate and tune.
If I had a megasquirt though I'd be buying two sets of TBs and seperating them.
Stu
mcerd1
posted on 4/1/12 at 06:05 PM Reply With Quote
if you can get away without respacing them its easier - but that doen't mean you can't respace them
not the cheapest but Bogg Bros. could easily sort you out: http://www.boggbros.co.uk
they are very easy to deal with and there work is first class
I got my carb's and manifold from them (2.1 pinto without respacing in my case)
bogg bros. respaced on a manifold for an Aston (pic from there Gallery)
[Edited on 4/1/2012 by mcerd1]
mark chandler
posted on 4/1/12 at 07:33 PM Reply With Quote
Get 2 sets of carbs off a triumph triple, or better still keep what you have and two sets of TB's and do not seperate but build the manifold to suit
Always cheap on Ebay
posted on 4/1/12 at 09:59 PM Reply With Quote
I re-spaced some CBR600 carbs - easy if you have a lathe to make spacers, etc. together with some experience in fabricating stuff from brass tubing (e.g. silver soldering).
This is what I ended up with:
Benzine
posted on 4/1/12 at 10:22 PM Reply With Quote
thanks everyone for the replies! Lots to think about, particularly interested in the idea of 2 sets of triumph (daytona) TBs. Means I'll have to stick with MS though I think i need to rip everything out and start again from scratch
Volvorsport
posted on 4/1/12 at 11:54 PM Reply With Quote
triumph triple for me here too .
you need 40 - 45mm id carbs / bodies min.
www.dbsmotorsport.co.uk
getting dirty under a bus
