Author: Subject: zetec install
richwill
posted on 5/1/12 at 01:24 PM Reply With Quote
zetec install
A mate has a 2.0 dohc engine and mt75 to fit into his locost but is now considering getting a zetec to fit instead. Will the gearbox fit to the zetec. If not what is needed to make it fit.
Also the hubs he is using have 5 stud pattern. Do mondeos have this pattern or are they 4 stud.
Many thanks
mcerd1
posted on 5/1/12 at 01:47 PM Reply With Quote
depends on the age of mondeo - the early models had 4x108 hubs (same as all the old fords)
the later ones (inc. the current ones) have 5x108, as do most of the newer fords
the mk3 granada / scorpio's had 5x112 hubs that look alot like sierra ones...
[Edited on 5/1/2012 by mcerd1]
big_wasa
posted on 5/1/12 at 04:01 PM Reply With Quote
Yeh the mt75 fits fine.
Use the mondeo flywheel and clutch.
You need a spacer on the mt75 thrust bearing or space the pivot point.
