Author: Subject: trouble with tintop - wont turn over
mads
posted on 8/1/12 at 07:01 PM Reply With Quote
Evening all,
Having trouble with the tintop this weekend. Was working fine yesterday morning. Went to use it yesterday evening and it wouldn't start. Didnt look too much into it, thought it might be the battery (though lights/stereo all working OK). Tried to jumpstart by connecting to other half's car, but still no joy. Figured battery may be dead as quite old. Have since replaced battery but still no joy.
Lights on dashboard come on but it wont turn over. Get a single click noise from engine bay when turn key and nothing more. Think it could be the starter motor? Anyone else got any other thoughts? How I can confirm / exclude it is that?
Thanking you all in advance.
mads
p.s. car is 1993 VW golf. working fine, can't see any loose connections etc and as said was working fine during day.
We gain knowledge faster than we do wisdom!
Life is not a journey to the grave with the intention of arriving safely in a pretty and well-preserved body, but rather to skid in sideways, thoroughly used, totally worn out and loudly proclaiming... "f*ck, what a trip!"
big_wasa
posted on 8/1/12 at 07:09 PM Reply With Quote
First port of call would be a loose or broken earth.
followed by the live.
then the starter itself.
se7ensport
posted on 8/1/12 at 07:26 PM Reply With Quote
The 'click' noise usually means the starter/starter solenoid has had it (if you have ruled out flat battery), as above it could be one of the connectors to it instead. If you have the space and a slope on your side try bump starting it to confirm that it is nothing else.
Andybarbet
posted on 8/1/12 at 07:46 PM Reply With Quote
Had same thing on my SAAB 95 last month, i ordered a starter motor from a local SAAB breaker, job done, it fired up 1st time.
I didnt get any warning of the failure, drove it 40 miles, got home & had a cuppa,, went back out & it just gave me a small 'click' without even trying to turn over.
I dont know anyway of checking if it is definately the starter though ???
Good luck
davidimurray
posted on 8/1/12 at 08:02 PM Reply With Quote
I had a similar problem a while back on my MG. Turned out to be a corroded connection on the starter.
Gallery 1 http://www.facebook.com/media/set/?set=a.116893465324.130778.601005324
Gallery 2 http://www.facebook.com/media/set/?set=a.245243755324.181913.601005324&l=a9831a9319
Gallery 3 http://www.facebook.com/media/set/?set=a.440671625324.232627.601005324&l=3f0d42c523
Gallery 4 http://www.facebook.com/media/set/?set=a.490098255324.297598.601005324&l=efb083b7df
Gallery 5 http://www.facebook.com/media/set/?set=a.10150244028550325.366987.601005324&l=583fd5cd3a
Gallery 6 http://www.facebook.com/media/set/?set=a.10150550640070325.430417.601005324&type=3&l=fe779b358c
Duratec Engine Swap https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f " target="_blank"> https://www.facebook.com/media/set/?set=a.10152527759580325.1073741828.601005324&type=1&l=40aae5e72f
posted on 8/1/12 at 08:28 PM Reply With Quote
Try giving the solonoid a clout with a hammer , sometimes it's just a sticking solonoid. If it is the starter make sure you change the small bush for the nose of the starter which is in the bell housing if your starter is the type without a "nose" complete with bush . Use a tap to draw it out, soak the new one in oil and carefully drift it into place. Check all connections and earths before condemming the starter, possibly rig up a small jump lead to activate the solonoid which eleminates any voltage drop through the ignition switch (VWs use a replacable electrical section of the switch)
macc man
posted on 8/1/12 at 10:39 PM Reply With Quote
I had a similar problem on my Vectra. Engine would not turn over. Fitted new starter no joy. Turned out to be the ring gear was loose on the flywheel. Got a mechanic to tack weld the gear through the starter hole in bellhousing. Saved a fortune not having to remove the gearbox.
speedstar
posted on 8/1/12 at 10:46 PM Reply With Quote
Try tapping the starter and solenoid with a hammer whilst someone else turns the key (so it clicks). Might give you an extra couple of trips, but does sound like the starter has had it
HowardB
posted on 8/1/12 at 10:51 PM Reply With Quote
+1, fixed a mates Renault with this handy tip!
Howard
