Author: Subject: hi seat belt mounts
whitstella
posted on 13/1/12 at 06:31 PM Reply With Quote
hi seat belt mounts
hi just wondering if anybody know the thread size for the mounting points????
and which way do they bolt on i've got a couple of dome washers.
cheers steve
daniel mason
posted on 13/1/12 at 06:42 PM Reply With Quote
I used eye bolts on my Mnr, and just clipped harnesses onto them
Brian R
posted on 13/1/12 at 08:31 PM Reply With Quote
Standard thread size for seat belt mountings I believe is 7/16 unf.
locoboy
posted on 13/1/12 at 11:11 PM Reply With Quote
As above, 7/16 UNF
Locoboy
posted on 14/1/12 at 10:58 AM Reply With Quote
As said standard thread is 7/16"UNF . It's common to have a shouldered spacer and a wavy washer, normal assembly is place the washer on the shoulder then the belt fitting and put the bolt through to clamp the spacer between the belt anchorage point and the belt fitting. The wavy washer stops any rattling about, I doubt it serves any other purpose
mistergrumpy
posted on 15/1/12 at 08:17 PM Reply With Quote
Maybe of interest to you is that I have Willans harnesses which as stated have a 7/16 mounting hole but that's it. There's no space for the mentioned spacers to allow the belt to swivel.
