Author: Subject: For Sale - GSXR1000 throttle bodies & filter
skidmark
posted on 15/1/12 at 09:16 PM Reply With Quote
Hello all,
I've finally decided to sell my GSXR1000 throttle body setup. I had these running very well on my previous C20XE engine (sound great and very responsive as you'd expect) and was going to fit them to my new zetec but decided to go down the plenum route instead. I was going to keep them for a future upgrade but I could do with the cash so unfortunately they have to go.
The throttle bodies are somewhere between K1 & K3 year I believe and are the re-spaceable type. They have been respaced to suit C20XE but can easily be adjusted by a few mm either way to suit a zetec or similar.
I have removed the secondary throttles and blanked / smoothed the holes, added machined spacers and throttle linkage extensions and also had some new fuel rail sections made up to extend the original fuel rail properly.
The original GSXR injectors and TPS are present, as are the electrical connectors / loom and manifold vacuum pipes.
Also included are fuel-resistant, steel reinforced hose sections and jubilee clips for connecting to a manifold.
The throttle bodies also come with a pipercross sausage filter with custom backplate incorporating original GSXR rubber velocity stacks (all same length) and a GSXR air temperature sensor. the filter has started to show a slight amount of weathering but is in excellent condition otherwise, as are the rest of the components.
Was looking for 200 pounds for a quick sale
skidmark
posted on 16/1/12 at 12:57 PM Reply With Quote
Sensible offers considered....
billy
posted on 16/1/12 at 06:18 PM Reply With Quote
Hi, Is there a inlet manifold to go with these?
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
skidmark
posted on 16/1/12 at 06:46 PM Reply With Quote
No, I've already sold the manifold unfortunately since I was converting over to a zetec and didn't need it!
roohunter
posted on 16/1/12 at 07:25 PM Reply With Quote
gsxr filter
hi there,
i already have these fitted but need the filter ,plate,rubbers if you split could you let me know
thanks
skidmark
posted on 17/1/12 at 10:35 AM Reply With Quote
Hi, I'm going to try to keep these together so I can use them again if they don't sell (the backplate and trumpets took a while to make / find). Thanks anyway.
skidmark
posted on 18/1/12 at 12:20 PM Reply With Quote
Last try before they go on ebay or I decide to keep them... now £150+postage.... bargain!
pjay
posted on 18/1/12 at 03:32 PM Reply With Quote
U2U sent
skidmark
posted on 18/1/12 at 06:52 PM Reply With Quote
Now sold (subject to payment)
Chris
