Author: Subject: Huge Garage Sale - Electricains look here
Krismc
posted on 22/1/12 at 09:06 AM Reply With Quote
Lost a major contract on friday, due to the building i was due to start went bust.
So i know i might use in future buy ive got no storage so to claw some money in to pay bills etc, all the gear from the job is for sale if you are interested in a job lot let me know.
Plus i added a few other items in there.
I know ill make a big loss on some stuff but thats the way it goes some times, i cant take every pic so just ask and ill post up what is neccessary.
Kris
> USED - Was £185 - Take £50 - Sentri Van Safe 1000 x 450 x 450mm (lid needs spot welding on hinge or drilling and screwing hence nice price!!)
> New - OFFERS - 30 Lenghts of tongue and Grove flooring 2400 x 150 x 20mm
> New - OFFERS - 16 x Yellow melomine coated chip board 930 x 190 x 20mm - perfect for garage shelves
> USED - Was £18 - Take £5 - Size 9 Boots worn for 1 week, Black Trojan
> New - 4 x Makita Grinding Discs 4 1/2 inch - Offers
> New - 5 x Makita Cutting Discs 4 1/2 inch - Offers
> New - No Nonsence Expanding Foam 750mm (Large tins) - Offers
> New - 4 x Disposable Overalls Size XL
> New - 2.5l Tin of Smooth Black Hammerite - Was £50 - Take £25 only bought 3 days ago
> USED - Opened but unused - Dickies Padded overalls Medium Was £84 Take £40 see http://www.dickiesstore.co.uk/photos/WP15000.jpg
> Worn a few times - Orange Fluoresant work jacket - Large
> New - (x2) 2Ft Slimline Fitting with tubes and starters
> New - (x2) 4Ft Slimline Fitting with tubes and starters
> New - (x2) 5Ft Slimline Fitting with tubes and starters
> New - (x20) 4ft Flouresant Tubes - Cool White
> New - (x25) 3ft Flouresant Tubes - Cool White
> New - (x15) 2ft Flouresant Tubes - Cool White
> New -(x3) 1ft Bulk head Emergency Lights Newey and Erye Was £35 each
> New - 100 x Various Baynot and Screw energy saving, standard 100w, Halogen bulbs etc just ask
> New - 100Mtrs 1.5m White Flex cable on drum
> New - 50Mtrs 1.5m White Flex cable on drum
> New - 100Mtrs Twin and Earth Grey on drum
> New - 7mm x 110mm SDS masonary Drills (x10)
> New - 7mm x 165mm SDS masonary Drills (x3)
> New - 6mm x 160mm SDS masonary Drills (x10)
> New - 5.5mm x 160mm SDS masonary Drills (x3)
> New - 10mm x 160mm SDS masonary Drills (x10)
> New - 10mm Steel Drills (x15)
> New - 11mm Steel Drills (x2)
> New - 13mm Steel Drills (x3)
> New - 3 x Small Garage DB's Prewired with Rcd, Switch and Indicator -£25each
> New - 3 x Bulk head fittings with Baynot cap bulb, and Switch prewired unit mounted on a galvanised bracket heavy duty £10each
> New - 10 x 1 Gang 2 Way 10ax Newey and Erye Switch white
> New - 10 x 1 Gang 25mm Slim line Newey and Erye patress/moulded back box white
> New - 5 x Metal Clad 13a Spur units DP Switched (with optional flex outlet) and include metal Back Box - Grey
> New - 12 x 250ml WD40 small tins £2each - (£20 the box)
Loads of nut packs, Screw packs, Plugs, O rings, Roll pins, C-clips, Oil, Grease tins and tubes, Bulbs, sockets
2 low voltage high output lighting sets:- Was £172/154 - Take £45
eBay - The UK's Online Marketplace
One is premounted in a vandle proof enclosure. If you got a new kitchen 4 will light up without any probs they are a high k so really white in colour (kitchens,bathrooms etc) bit too white for living rooms and bedrooms but only 3.3w so keep the missus happy when paying the bills - and i mean really bright!
I also got (x8) 4ft twin fluoresant fittings 1p65 enclosed with tubes and starters, pre wired with a lenght of cable on them and plug on each end, so simple to put up remove from box, screw to ceiling, plug into next light etc and wire in the last one, these go with the small garage DB's ive got and ive got pre wired plugs, sockets switches etc so you can plug them all together and wire in one end or you can buy seperatly and cut the plug off, ive been selling for a bargin of £21.99 on ebay but £17.99 too you lot, postage is expensive from £8 - £12 depending on which ballast is in them but still makes them cheapest. You could arrange a courier and i could leave at home with wife.
Emergency alarm - £18.99
Got lots of work gloves with protective coating similiar to Dyemmas, cost £5 each, take £1.50, in 8, 9 and 10s average to large man is 9, every other freak is 8 or 10. 500 pairs
Some more that might interest you...
Canon EF 75-300mm f/4-5.6 III
Canon ET - 60 lense hood
Lense UV filter
Currently £199 on Amazon and £150 ish on ebay so i think with extra cover and filter £100 ono delivered is a good price, still boxed has been used a couple of times in superb condition
ODYS 7 INCH PORTABLE TV COST £120 - £30 never used just sat in cupboard....here it is for sale else where....
http://www.eandgdirect.com/Novel-Portable-Player--ODYSPortable-televisions/dp/B005BQGAO8?traffic_src=froogle&utm_medium=organic&utm_source=fro ogle
Cheers lads (and ladys)
I KNOW THE FIRST QUESTION I GET WILL BE POSTAGE....
Try and collect the large Items if you can, from newcastle or arrange your own courier i can give sizes and weights, i will post small items and can send however you like, ill charge the exact cost is costs me.
[Edited on 22/1/12 by Krismc]
Krismc
posted on 22/1/12 at 10:21 AM Reply With Quote
Makita battery Under offer.
roohunter
posted on 22/1/12 at 10:30 AM Reply With Quote
battery
hi there,
is it a lxt battery?
thanks
Krismc
posted on 22/1/12 at 10:34 AM Reply With Quote
Makita Battery Sold
hicost
posted on 22/1/12 at 04:01 PM Reply With Quote
TV
Hi
will take the ODYS 7 INCH PORTABLE TV
Give me the postage to 66 Charrington Way, Broadbridge Heath, Horsham West Sussex RH12 3TH
I can paypal you the money or whatever way,
James
07785 391887
"I cant do that without accidentally grabbing hold of the work of the divine potter"
emsfactory
posted on 22/1/12 at 04:48 PM Reply With Quote
u2u
Krismc
posted on 22/1/12 at 05:21 PM Reply With Quote
Originally posted by hicost
Hi
James
07785 391887
You have U2U
Krismc
posted on 22/1/12 at 09:55 PM Reply With Quote
TV - SOLD
BATTERY - SOLD
FLOORING - UNDER OFFER
SDS BITS - UNDER OFFER
Lighting - High Interest no firm offers
samjc
posted on 23/1/12 at 06:12 PM Reply With Quote
Flex cable is it 3 core flex ??
Krismc
posted on 23/1/12 at 06:44 PM Reply With Quote
Yes, 3 Core Flex sorry.
Krismc
posted on 23/1/12 at 07:43 PM Reply With Quote
First LED lighting kit sold. 1 kit left
T66
posted on 23/1/12 at 08:51 PM Reply With Quote
Kris,
Check your u2s - The son is after your mobile number.
cheers
Ivan
Krismc
posted on 23/1/12 at 09:09 PM Reply With Quote
Sorry my mistake, he now has both numbers.
samjc
posted on 24/1/12 at 08:48 AM Reply With Quote
U2u me a price on the flex.
Krismc
posted on 24/1/12 at 08:38 PM Reply With Quote
Ivan sent a txt, let me know if he def wants it and u2u sent
dhutch
posted on 25/1/12 at 04:35 PM Reply With Quote
U2U Sent Re Fluor Fittings.
Krismc
posted on 25/1/12 at 05:07 PM Reply With Quote
Led lighting kits now selling on ebay. Currently at £45
Flooring available still
Lads who payed sun, parcels left tues am. Thanks
Krismc
posted on 28/1/12 at 12:09 PM Reply With Quote
ITEMS STILL LEFT
> USED - Was £185 - Take £50 Now Take £40ono - Sentri Van Safe 1000 x 450 x 450mm
> New - Was £180 - Take £70 Now Take £50ono - 30 Lenghts of tongue and Grove flooring 2400 x 150 x 20mm
> New - Was £47 - Take £30 Now Take £20ono - 16 x Yellow melomine coated chip board 930 x 190 x 20mm - perfect for garage shelves
I also got (x8) 4ft twin fluoresant fittings 1p65 enclosed with tubes and starters, pre wired with a lenght of cable on them and plug on each end, so simple to put up remove from box, screw to ceiling, plug into next light etc and wire in the last one, these go with the small garage DB's ive got and ive got pre wired plugs, sockets switches etc so you can plug them all together and wire in one end or you can buy seperatly and cut the plug off, ive been selling for a bargin of £21.99 on ebay but £17.99 too you lot, postage is expensive from £8 - £12 depending on which ballast is in them but still makes them cheapest. You could arrange a courier and i could leave at home with wife. found postage for £5.99
Lense UV filter
Currently £199 on Amazon and £150 ish on ebay so i think with extra cover and filter £100 ono delivered is a good price, still boxed has been used a couple of times in superb condition - £89 on ebay
