Author: Subject: Bike TB cable linkage
Bizarro
posted on 22/1/12 at 05:05 PM Reply With Quote
Can somebody post a pic of throttle cable linkage for GSXR bike throttle body set up?
Been in garage this afternoon thinking of various ways to ensure a good throttle return and was wondering how others have gone about it, picture of what I have now:
Throttle linkage
Throttle linkage
monck
posted on 22/1/12 at 05:41 PM Reply With Quote
im also after some ideas on this mate so ill keep an eye on this thread ....
Where have you had them trumpets from ? they look better than my standard rubber ones
Bizarro
posted on 22/1/12 at 06:43 PM Reply With Quote
Trumpets were off the bay, cant resist 'shiny' things
pjay
posted on 22/1/12 at 07:01 PM Reply With Quote
I used the side plate that came with the GSXR1000 ITBs I got (had to adjust the throttle pedal range since the amount of cable movement is designed for a bike hand throttle - obviously). Do you have the original side plate?
I'll post a pic later if I can get out to the garage.
bccox18
posted on 22/1/12 at 08:34 PM Reply With Quote
Hope these help.
For the trumpets, trimmed down Weber 45 ones fit a treat.
Bob
Bizarro
posted on 22/1/12 at 08:43 PM Reply With Quote
Originally posted by bccox18
Hope these help.
Bob
Cheers, is that the original bike 'side plate'? If so Im not sure if I have all of it!
pjay
posted on 22/1/12 at 08:55 PM Reply With Quote
Same side plate and set up as I have (no additional pics required in that case).
monck
posted on 22/1/12 at 11:25 PM Reply With Quote
bccox18 what throttle cable did you use ?
bccox18
posted on 22/1/12 at 11:47 PM Reply With Quote
I ended up using a brake cable from a bicycle.
The nipple at the end had to be filed down a little bit to fit into the holder on the linkage but it works perfectly.
Bob
monck
posted on 23/1/12 at 07:06 AM Reply With Quote
Cheers mate
Bizarro
posted on 5/2/12 at 05:09 PM Reply With Quote
After a bit of searching in the garage I have found the rest of the bike throttle linkage and got it sorted today, thanks for the pics..
The return spring on the throttle bodies doesnt seem strong enough to fully return with the cable attached, so Ive fitted an additional spring on the pedal and it now snaps shut quite nicely.
I can fully open the throttle before the pedal touches the bulkhead, to prevent stretching/breaking the cable would it be a good idea to fit some kind of positive 'stop' on the pedal?
I'm thinking something as simple as a bolt through the bulkhead so the back of the pedal touches aganst the bolt at full throttle, and Im not stretching the cable?
DIY Si
posted on 5/2/12 at 05:38 PM Reply With Quote
If the top of the pedal travel is where you want it and is comfortable, then yes some sort of stop is the best way to prevent stretching the cable. A simple bolt will do, but make sure it's aligned well with the pedal.
Sun Tzu, The Art of War
