Author: Subject: emerald k6
needforspeed
posted on 25/1/12 at 08:39 PM Reply With Quote
emerald k6
is anyone familiar with the k6?
A1
posted on 25/1/12 at 09:07 PM Reply With Quote
if the k3 is anything to go by itll be good.
needforspeed
posted on 25/1/12 at 09:10 PM Reply With Quote
im running it already, well when i say running i cant actually get it running!
big_wasa
posted on 25/1/12 at 09:17 PM Reply With Quote
Its on my shopping list for my next project But never used emerald. Wired lotts of other brands.
Whats the problem ? You will need more info of what its doing and not.
needforspeed
posted on 25/1/12 at 09:24 PM Reply With Quote
i just need an emerald expert if theres any mappers out there! to do with the ignition drivers and trigger patterns
Nash
posted on 25/1/12 at 09:41 PM Reply With Quote
I have the K6 installed on mine. When I first installed it I had a few problems getting it to fire up. I rang Dave Walker at Emerald (although I didn't buy direct from him) and he emailed me a map to get it running. It fired up on that and ran ok.
Have you rang Dave?
........Neil
Build It, Buy It, Drive It:
Southern Kit Car Club
needforspeed
posted on 25/1/12 at 09:45 PM Reply With Quote
going to ring him tomo tho they supplied a base map when i bought it what engine are you running? the strange thing is
mines 24-2 and only 22-1 is listed. now they said if i select 22-1 it would actually be 24-2!?? sounds a bit random. when i fire it it just spits back and coughs then fuels up as if the timings out
needforspeed
posted on 25/1/12 at 09:46 PM Reply With Quote
also theres no options for where it picks up leading or trailing edge of the pick up
ashg
posted on 25/1/12 at 09:52 PM Reply With Quote
there is a man. his name is dave walker very helpful chap especially when you have bought one of his ecu's
[Edited on 25/1/2012 by ashg]
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
needforspeed
posted on 25/1/12 at 09:53 PM Reply With Quote
im actually contemplating taking it to him then i can just collect it finished!
Nash
posted on 25/1/12 at 10:00 PM Reply With Quote
My setup up is a 2.0L Zetec on Jenveys. Is your timing 180 degrees out? I've seen that before?
needforspeed
posted on 25/1/12 at 10:09 PM Reply With Quote
ive tried changing them round on the ignition driver page? its so close to going
Nash
posted on 25/1/12 at 10:12 PM Reply With Quote
Do you have enough juice in the battery? May be a silly question but I had a problem. Also when turning it over do you get a red / green pulsing light on the side of the ECU?
.......Neil
needforspeed
posted on 25/1/12 at 10:14 PM Reply With Quote
yep its all correct its definately down to a setting or them giveing me a bum steer with the trigger pattern. but they seem to have an exeptional rep
Nash
posted on 25/1/12 at 10:21 PM Reply With Quote
This is my car on the rollers at Emerald last Jan after the install. Thats Dave in the drivers seat doing his thing. It is a thing of beauty to watch AND what a difference. Stick with it and you will find something obvious I'm sure.
http://www.youtube.com/watch?v=noNz16Jp0hU
..........Neil
[Edited on 25/1/12 by Nash]
omega 24 v6
posted on 26/1/12 at 12:45 PM Reply With Quote
Get a bog std timing light and check it's firing at the right time with regards to TDC. That'd be your first port of call IMHO
needforspeed
posted on 26/1/12 at 08:17 PM Reply With Quote
wasnt as easy as that unfortunately being a bike engine but all sorted now :-) happy days!!!
posted on 26/1/12 at 08:20 PM Reply With Quote
What was it? It may save someone else grief!
needforspeed
posted on 26/1/12 at 08:23 PM Reply With Quote
simple as the trigger wheel id worket it out for the leading edge rather than the trailing edge of the missing teeth, funnily enough i had tried the number before just incase but didnt work! :-/ anyway sorted now thank goodness had a play and is running sweet first drive in a few weeks then mapping!
