stig mills
| posted on 6/2/12 at 10:36 PM |
Busa
Hi, I am going to start a BEC build in the next few days, I was keen on Busaing it. Mevabusa middy perhaps!
It will weigh around 400kgs. So I was wondering what sort of performance figures I could expect.
Any comparisons of similar or higher weight cars with a non turbo busa engine in would be great.
0-60?
Any downsides?
Ratios?
Westgarage chain diff with reverse opinions?
Thank you very much in anticipation, Stuart
ReMan
| posted on 6/2/12 at 10:56 PM |
I'd expext 400kg with a busa is going to be sub 4 secs
If it going commercial though why not steer away from the busa to someting more affordable the times on an R1 at 400kg ar not going to be that
differnt?
www.plusnine.co.uk
:{THC}:YosamiteSam
| posted on 9/2/12 at 08:28 PM |
downsides - parts costs - real pricey
carnymouse
| posted on 9/2/12 at 10:15 PM |
BUSA ENGINE IS THE WAY TO GO. WITH A BIT OF SHOPPING AROUND YOU CAN BUY A COMPLEAT BIKE FOR AROUND £1,600 STRIP OFF WHAT YOU DONT NEED AND STICK ON
EBAY YOU CAN END UP WITH ENGINE ECU ETC FOR AROUND £800
carnymouse
BobM
| posted on 10/2/12 at 06:59 AM |
Why do you want a Busa Stig? Most of the RGB guys are getting as much power out of 2007/2008 litre superbike engines - cheaper and lighter. Also all
running billet wet sump which saves weight and cost over a dry sump.
I switched from a Fury with a Busa engine to a middy BDN with a ZX10 and noticed no loss of drivability. On the rolling road the ZX10 was 79 ft-lbs
versus the busa's 90.
Not very Locost but very BEC
Andy North
| posted on 12/2/12 at 01:41 PM |
I am on my third mid engine busa. You will struggle to get below 400kg so yo may well be better off going the one litre route as the engines are much
lighter.
I was told the speads with a K8 is 411kg, but it is unlikely.
Siduna
| posted on 13/2/12 at 09:08 PM |
BEC Middy
Hi all!
Newbie here. I'm just about to start building a middy with a Busa engine (the engine is on it's way home as I'm writing this). Being
the first build of this type all advice is welcome!
Plan is to design a sprocket gear transmission (instead of chain drive) and build a mechanical reverse gear in the centre line of the
"middle" gear (between the gear wheel on the outgoing shaft from the engine and the gear on the Torsen diff (yes, intention is to obtain a
Torsen LSD). Similar design has been made before (without reverse gear) :
http://www.ret-monitor.com/articles/1325/more-on-bike-engined-cars/
Two gear wheels will be mounted where the middle gear is in the lower most picture. Two wheels, one into the reverse gear box and one going out. One
solid axle inside at "tube axle" (not being English, hence the poor choise of words). This will enable me to place the diff more in the
centre of the car. Does anyone understand what I'm writing?
Should anyone understand what I'm writing and have any experience in "gear wheel transmissions" I'll be happy for any advice
in this matter!
Regards,
stig mills
| posted on 5/3/12 at 10:59 PM |
Many thanks for the help. Sorry for the late reply. I have done R1 stuff b4, great engines but fancied a Busa as everyone raves about them.
Possibly not the best value but the parts I sold off from the bike helped enormously. I have completed the fabrication work now so I will show it at
Stoneleigh. Looking forward to giving it a blast.
