Author: Subject: Diff flange
Tinks1
posted on 7/2/12 at 01:03 PM Reply With Quote
Diff flange
Hi
I have noticed a significant amount of oil leaking from my 7" Seirra diff.
The area that is leaking is around the "washer" under the locking nut on the splined shaft. This washer
seems to be a permanent fit and rotates. Is this correct and why does it rotate.?
How is this sealed to stop the oil from leaking down the splines and out through the nut/washer.
Any help would be appreciated.
John
Chippy
posted on 7/2/12 at 01:49 PM Reply With Quote
The "washer" is a dust/muck deflector, to stop stuff going in to the oil seal. Behind the "washer" is an oil seal which sounds as though it needs relaceing, not a big job but may need the diff removed, depending on how much room you have to get at it. HTH Ray
Tinks1
posted on 7/2/12 at 02:00 PM Reply With Quote
Thanks for that ..... does the washer need be pressed out as it seems
to be fixed in place
Chippy
posted on 7/2/12 at 02:05 PM Reply With Quote
The washer is in fact part of the drive plate, and comes off as one piece once you have removed the nut. Cheers Ray
