New Topic New Reply
Author: Subject: Thread protrusion
Rogthebandit
posted on 18/2/12 at 11:01 PM Reply With Quote
Thread protrusion
Hi
Just building up the suspension on the mk. Can anyone give me advice on the thread protrusion for the iva inspection. I have about 2 threads showing past the nylock. Just want to make sure them there testers are not going to fail me when I get it tested. Also do the suspension bolts need to be greater than 8.8s ?
Rog
daviep
posted on 18/2/12 at 11:21 PM Reply With Quote
2 threads is good enough as is 8.8
designer
posted on 19/2/12 at 09:06 AM Reply With Quote
The minimum thread projection is 1 1/2 threads.
posted on 19/2/12 at 09:34 AM Reply With Quote
As protruding threads as above .. so no worries.
8.8 or grade 8 are fine for suspension bolts provided they are adequately sized to start with but 10.9 is better..
Rogthebandit
posted on 19/2/12 at 10:04 AM Reply With Quote
Cheers chaps, that's sound, I shall carry on with the build :-)
Davegtst
posted on 22/2/12 at 06:30 PM Reply With Quote
I've just checked mine and I only have 1 thread at the most. Looks like I need longer bolts which is strange as these were the bolts mk supplied. Would there be any problem using stainless bolts?
Andybarbet
posted on 22/2/12 at 06:52 PM Reply With Quote
As far as I know stainless bolts are a no go on suspension due to being brittle compared to steel ones.
I will let the Locost fountain of knowledge correct me ive been mis-informed
iank
posted on 22/2/12 at 07:14 PM Reply With Quote
I believe you are correct, I believe stainless would likely fail IVA if used on suspension.
8.8 is said to be best for suspension (iirc there are two theories either as an 8.8 bends rather than snapping like harder 12.9 if you hit a curb too hard you're likely to keep the wheel all be it at a funny angle, or it will protect the chassis more by breaking where the chassis will tend to bend and suspension brackets rip off before a 12mm 12.9 lets go.) Take your pick, but 8.8 passes IVA fine.
Anonymous
Stott
posted on 22/2/12 at 07:15 PM Reply With Quote
Don't use stainless for the reason above
As for a solution to your problem get a load of form b washers and replace all your normal ones which will save you changing all the bolts.
They are about 1/2 - 3/4 thickness so will get a little more thread showing.
Stott
posted on 22/2/12 at 07:23 PM Reply With Quote
Are flange nuts accepted by "the powers that be" as self locking ? they are generally a lower height (height = dia) and don't require washers.
Neville Jones
posted on 23/2/12 at 10:39 AM Reply With Quote
Flange nuts aren't accepted, as they aren't self locking. I've even had aero stiff nuts questioned.
Two threads protruding is mandatory for IVA.
Above is for Southampton and Reading, other stations may differ in interpretation.
Nev.
loggyboy
posted on 23/2/12 at 10:55 AM Reply With Quote
Nev.
Reading?
Davegtst
posted on 23/2/12 at 03:08 PM Reply With Quote
Stott
Thanks, i did think of this but i don't think it would be enough. I have just bought a load of 8.8 bolts 5mm longer which are a lot better. It would drive me mad if i failed the IVA for the sake of £10 worth of bolts.
posted on 23/2/12 at 05:06 PM Reply With Quote
Thread copied for future reference.
Neville Jones
posted on 23/2/12 at 06:11 PM Reply With Quote
Nev.
Reading?
Yep, used to be an SVA station in Reading. I've use Southampton nowdays.
Nev.
jacko
posted on 23/2/12 at 08:10 PM Reply With Quote
Why not fit half nuts you can buy them and they will give you enough thread
M12 HALF NUTS / LOCKNUTS 12mm BZP (Pack 20) | eBay
[Edited on 23/2/12 by jacko]
phelpsa
posted on 26/2/12 at 03:22 PM Reply With Quote
Kaynuts are generally quite slim and aerospace certified.
http://www.nasbolts.co.uk/acatalog/Metric_K_Nuts.html
Not cheap though
MEERKAT
posted on 28/2/12 at 06:21 PM Reply With Quote
Can you have too much thread showing?
"To alcohol, the cause and solution to all of life's problems"
- Homer J Simpson
New Topic New Reply
