Author: Subject: Pinto set up
Tinks1
posted on 28/2/12 at 01:54 PM Reply With Quote
Pinto set up
Hi Guy's I know this has been covered before but not really got the answer.
I rebuilt my Pinto 2.0L over the winter and fitted a new standard cam shaft, followers and springs. I set up
the crank to TDC the cam sproket so the pointer hit the dot and the rotor arm pointed at no 1 on the
dizzy.
The pinto started first time but I am experiencing a "TAK TAK" noise which sounds to be at the front end
under the cam cover. I have checked and re-checked the valve clearances these are OK.
I do have trouble when trying to set the timing using a strobe that the timining marks do not appear stationary
the fluctuate..... the vacuum advance is disconected
Any help would be greatly appreciated.
John
mark chandler
posted on 28/2/12 at 03:44 PM Reply With Quote
The follower retaining springs fit to ears on the adjustment posts, if these are pointing the wrong way then it will clack so have a look here, easy to miss.
25 years since I had one so cannot tell you the right way around.
With a new cam it will be very quiet even with the timing all over the place, suggest you treat as different faults. Dizzy may just need a strip and clean, sticky weights or loose springs.
While running top off you can push a feeler gauge under each lobe to find the noisy one, valves will not hit just watch the flicking oil , also make sure each lobe is being sprayed.
[Edited on 28/2/12 by mark chandler]
Andy D
posted on 28/2/12 at 03:56 PM Reply With Quote
And check the cam isn't catching the spray bar. Should be OK with a standard cam but some higher lift ones get close.
Tinks1
posted on 1/3/12 at 12:42 PM Reply With Quote
Having done further investigation, I have found where the problem is but not
sure what to do.
The TAK TAK noise disappears if i pull off No.1 plug lead. I have tried all the others
and it is still there, swapped leads and plugs and the only thing that works is to
pull off No1 lead.
Any suggestions/help appreciated
John
posted on 1/3/12 at 08:16 PM Reply With Quote
Try changing the HT lead and make sure that the spark plug is tight Also check the exhaust manifold isn't leaking
[Edited on 1/3/12 by rusty nuts]
