TheKingofBling
| posted on 15/3/12 at 06:41 PM |
english axle wheel bearings
Ever since a full rebuild on my english axle i cannot stop the wheel bearings leaking after fitting brand new items
From speaking to many people the bearings im using seem to be of very poor quality and the oil is leaking through the bearings themselves. They have
the o ring on the outer casing
SKF rear bearings cannot be found for love nor money in the uk.
Any ideas where i can find a decent quality bearing that will solve my issues.
DIRTY DOGG RACING
pewe
| posted on 15/3/12 at 07:01 PM |
I would give these guys a call. They were really helpful when I need an odd-ball bearing recently - and their prices are more than sensible.
HTH.
Cheers, Pewe10
Bearing Boys
| posted on 15/3/12 at 07:40 PM |
You may be able to get some new old stock from somewhere like Past Parts in Bury St Edmunds
UncleFista
| posted on 15/3/12 at 08:17 PM |
I'm interested in this too, we keep replacing ours with the o-ring ones and they're crap.
I'd assumed they were cheapo Chinese parts on eBay and ordered a much more expensive one from Burtons.
When it arrived it was the same as the cheapo ones, that bloody o-ring..
It's not been fitted yet, but I expect the 0-ring will be shaved off as usual and we'll be back to square one..
If you find a supplier of the old type without the o-ring, post here please
Tony Bond / UncleFista
TheKingofBling
| posted on 15/3/12 at 08:28 PM |
My last lot were from burton, no markings on them and generally s***e.
If i find a supplier of decent bearings will keep you posted Unclefesta, that o ring is doing nothing, they are that poor they leak through the
bearing themselves.!!!
DIRTY DOGG RACING
macc man
| posted on 15/3/12 at 08:50 PM |
It is a while since I looked at an axle but do they not have an oil seal inside the casing that runs on the halfshafts. I had to replace two a while
back. This would make more sense than relying on the bearing to seal the oil in. Just a thought.
TheKingofBling
| posted on 15/3/12 at 09:10 PM |
Ah yes macc man, there are two different sized bearings, the ones im after are the larger of the 2 used on the rs 2000, no seal on those im afraid
DIRTY DOGG RACING
perksy
| posted on 15/3/12 at 10:39 PM |
Evenin' Blingy
Don't suppose Squires do these to go with their updated driveshafts ?
The Rally boys must get them from somewhere
I'll email steve...
PS
ANY Markings on the ones you have now ?
SKF ones would have a coding on the outer ring so if you know what you need it *might* make them easier to find
[Edited on 15/3/12 by perksy]
TheKingofBling
| posted on 15/3/12 at 11:08 PM |
Evening Buddy.
The part number for the SKF bearing is VKBA 960.
There is none in the uk anywhere mate.
Be interesting to see what steve says mate.
DIRTY DOGG RACING
Chippy
| posted on 15/3/12 at 11:40 PM |
Don't know if you have tried these people, may be worth a punt. HTH Ray
Simply bearings
dhutch
| posted on 15/3/12 at 11:48 PM |
Cant help, or even recall what make the bearings i have sitting to be fitted are, but try calling 'Rally & Competition Equipment' just
north of stoke on trent which is where I ended up going for a RS2000 halfshaft.
Daniel
