surrey_100e
| posted on 18/3/12 at 07:32 PM |
Focus ST225 (Volvo t5) engine wiring
Hi Guys,
Dont know if im in the right place but just need some advice. Ive got a focus st engine (the volvo t5) which ive fitted to my ford 100e. Ive dry
sumped it, custom flywheel, clutch etc, custom intercoolers, radiators, t5 cosworth gearbox, the lot.
Im now at the stage where im looking at wiring it up and sorting the engine management. Ive got the original ecu and engine loom which i want to run
it on but i imagine there is some immobiliser built it? How would i get round this?
Im currently trying to source the interior loom to make things easier but am thinking do i really need it?
Any help would be much appreciated.
Martin
tilly819
| posted on 18/3/12 at 07:42 PM |
Do you have the original Key and ignition barrel???? if it is like most modern cars they will be matched to the ECU
thats a DAM fine looking machine you have built there by the way
tilly
[Edited on 18/3/12 by tilly819]
F20C Haynes roadster 440 BHP/Tonne www.youtube.com/handmadeextreme
daniel mason
not totally sure on the answer to your question but you are in the right place, that looks awesome!
personally i would opt for aftermarket ecu but obviously budget is a consideration.
CRAIGR
| posted on 18/3/12 at 07:43 PM |
Can't help with the wiring but like that a lot Martin .It looks superb
Welcome to te forum too
liam.mccaffrey
| posted on 18/3/12 at 07:49 PM |
i think the focus engine ecu will definately have an immobiliser, whereas the older volvo ecus probably won't or it will be easy to work around.
I've have read that the volvo 850 ecu is very flexible
I'm using a t5 engine and had always planned to go with an aftermarket ecu and a custom loom.
If you odn't mind me asking I'd be interested to know more about your custom flywheel clutch and drysump. Is it something you dsigned and
had made or did you buy?
Should have said too I love the look of the project
[Edited on 18/3/12 by liam.mccaffrey]
Build Blog
Build Photo Album
surrey_100e
| posted on 18/3/12 at 08:14 PM |
thanks everyone.
Unfortunately i dont have the keys or ignition barrel, just literally the engine loom and ecu.
I was originally going to use vipec v88 management but the cost was too much to warrant at the moment. Maybe in the future but i just wanted to get it
running for now.
Heres a few pics of some bits ive made and had made.
The dry sump set up is a pace bg high flow pump and a dry sump pan that a guy made a couple of them a few years ago.
The flywheel was a built by ttv racing to suit volvo s60r clutch plate and im using a ap 6 paddle clutch with hydraulic release mechanism.
big_wasa
| posted on 18/3/12 at 08:51 PM |
If your local I would love a crack at an st engine managment. I love playing with ecu's but I really dont like your chances. Even if you are
able to use the immobilizer the ecu will be can-bus and require all sorts of inputs.
Being Volvo bassed I would look to an older volvo ecu and loom.
Whats your bell housing of ?
perksy
| posted on 18/3/12 at 09:58 PM |
Welcome
That car of yours is lovely
I'd be surprised if you could get that ECU to work tbh
Might be worth having a look on the Passion ford and Turbo sport forums to see if anybody has been lucky ?
Remember chatting to one of the lads at Westfield when they first brought out the XTR4 with the Audi engine and
They had tried to use the standard ECU, but it was a nightmare as it was always looking for sensors and kept throwing fault codes
They ended up going MBE in the end iirc
Is this something a Megasquirt could help with ?
If it is it would help keep the cost down
surrey_100e
| posted on 19/3/12 at 06:49 PM |
im in surrey, looks like its a bit too far
Like i said i have the engine loom, thats connected to everything on the engine and theres nothing left to plug in in that area so i was hoping to
utilise that and go from there... to where i do not know just yet.
The bell housing is from a 960 auto box and i made the adaptor plate to mate it to the cosworth box
Being 5 cylinder and having vvt the engine management systems available all seem to be on the pricey side.
big_wasa
| posted on 19/3/12 at 07:21 PM |
Yep 5 pots are not easy to sort aftermarket. I run the oem ford ecu in my 7 I can do them upto around year 2000 after this I dont know how the
security compares and what other inputs it will need. The ecu's went from eec to black oak and can-bus aswell.
Ive never had the space or money to find out.
It CAN be done but you may need a running donor to reverse engineer it.
First thing to find out is if the ecu is Ford or Volvo bassed. I really would look to the older volvo ecu's
Volvorsport
| posted on 19/3/12 at 08:35 PM |
st ecu will need the immobiliser sorting out ,
earlier volvo ecu will be much easier to sort out ... it may not have the vvt part tho so , you may be stuck .
nice work by the way . nice to see austens work getting used....
did you keep the drawing for the T5 gearbox adapter ? because you can now sell them to all and sundry who want RWD 5 cylinders.
www.dbsmotorsport.co.uk
getting dirty under a bus
surrey_100e
| posted on 21/3/12 at 08:00 PM |
cheers guys.
Well ive had a think and im going to go down the vipec v88 ecu route, will make life much easier and will be worth it in the end, just means a bit
more saving, also i can still use the existing loom so all is not lost.
And yes i still have the templates knocking about somewhere for the adaptor
Will keep you all updated
daniel mason
| posted on 21/3/12 at 08:42 PM |
how much is the ecu? as im sure there are many others which would do the job.
