Author: Subject: MK Locost Part needed
nilocp
posted on 20/3/12 at 09:10 PM Reply With Quote
I need the following parts for my MK Locost
2.9 Escort rack
Crossflow exhaust manifold
nuts for transit joints
4 shocks and springs
bias pedal box cable clutch
Stuart Taylor type engine mounts xflow
Propshaft front yoke type 9, or front part of a prop, or even a full prop to shorten, english axle large flange
Sierra steering wheel boss WHY?
Group 4 steering joint
Alloy header tank
13in x 6 alloy wheels
Type 9 gear lever extension, to move lever back
I am sure there will be some more!!
Colin
Andybarbet
posted on 20/3/12 at 09:24 PM Reply With Quote
Not much help but i got my transit drop link nuts from GBS for a couple of quid.
nilocp
posted on 20/3/12 at 09:28 PM Reply With Quote
Andy, who are GBS please?
Colin
Andybarbet
posted on 20/3/12 at 09:38 PM Reply With Quote
Great British sportscars:
http://www.robinhoodsportscars.co.uk/
It might be worth trying a company called kit parts direct too:
http://www.kitpartsdirect.com/
Ive seen the nuts at the kit car shows too so if your planning on visiting one this year you will almost certainly get them there, might be worth checking your local ford dealer too, they sometimes surprise with prices.
Good luck with the search
[Edited on 20/3/12 by Andybarbet]
nilocp
posted on 20/3/12 at 09:48 PM Reply With Quote
Thanks for the tip.
I have tried the Ford dealer. They reckon there is no nut on the Transit. It fastens with a clamp and pinch bolt.
Unless anyone has a part number...........
CP
yamapinto
posted on 20/3/12 at 10:34 PM Reply With Quote
I can help with the type 9 gearbox extention and four coilover shocks and perhaps a few more bits
daviep
posted on 21/3/12 at 08:28 AM Reply With Quote
Originally posted by nilocp
Thanks for the tip.
CP
Which nuts do you need, the one which secures the ball joint into the upright or the lock nut for for the shank / wishbone?
Sounds like the dealer was talking about the shank.
Davie
nilocp
posted on 21/3/12 at 08:42 AM Reply With Quote
Davie the nuts that go on the shank as you call it. Are they M16 or M18 fine?
Colin
stuart collins
posted on 21/3/12 at 10:00 AM Reply With Quote
Message sent
Marcus
posted on 21/3/12 at 08:01 PM Reply With Quote
The nuts are M18 x 1. I got brass half nuts from a hydraulic parts supplier (Thorite) for not a lot of money.
Marcus
Because kits are for girls!!
nilocp
posted on 21/3/12 at 09:22 PM Reply With Quote
Marcus, brass against steel in that sort of application is not good, in my opinion!!
But what do I know?
nilocp
posted on 26/3/12 at 10:19 PM Reply With Quote
MK Locost parts needed some more!
Not doing very well here, but thanks for the pm's.
I have got an exhaust manifold now, but that is all!!
Further items needed:
crossflow modified head
silencer (new?)
narrow seats
front mud guard brackets Cortina hubs
Front indicators
Anyone do a basic wiring loom??
Colin
RK
posted on 26/3/12 at 10:36 PM Reply With Quote
Don't GBS do all that?
nilocp
posted on 27/3/12 at 07:33 AM Reply With Quote
Sorry looking for second hand if possible.
kipper
posted on 27/3/12 at 02:29 PM Reply With Quote
Hi Collin.
I have a set of 40 dcoe webbers on a Xflow manifold for sale.U2U me if interested
Denis.
Where did that go?
nilocp
posted on 27/3/12 at 04:37 PM Reply With Quote
Denis, already got Webers thanks.
Colin
A1
posted on 28/3/12 at 11:50 AM Reply With Quote
ive got a prop in the garage that might be of use to you...its an escort one i think.
are these the engine mounts youre after? plus i have a sierra steering wheel, but not a boss, you can get an omp one for about 25 quid from rallynuts.
nilocp
posted on 28/3/12 at 08:13 PM Reply With Quote
Thanks for that. The prop if it is a Mk2 will not go into the gearbox.
No those are not the engine mounts.
Thanks for the offer on the steering wheel, but I have aload of decent leather rim wheels, just need a boss to suit.
Thanks once agian
Colin
