Author: Subject: ab performance paddleshift
pauladamss
posted on 27/3/12 at 03:36 PM Reply With Quote
My paddleshift arrived today, can any one tell me if there is anything to hold the piece that slides over the column on or is it such a tight fit that it stays put. (hope that makes sense to someone)
designer
posted on 27/3/12 at 04:00 PM Reply With Quote
Just ask AB performance, they sold it.
Didn't you ask about it when you ordered?
andyfiggy2002
posted on 27/3/12 at 05:37 PM Reply With Quote
on the paddleshift tube aren't there a couple of small threaded holes with grub screws that once tightened dig into your existing column to hold the whole assembly in place?
[Edited on 27/3/12 by andyfiggy2002]
pauladamss
posted on 27/3/12 at 06:34 PM Reply With Quote
No there is a hole each side of the tube i have to drill and tap a hole each side of the colomn so that i can put a bolt in to hold it apparently.
