Author: Subject: Zetec to Type 9 Starter Motor
mkeats02
posted on 30/3/12 at 01:41 PM Reply With Quote
Hi
I am fitting a type 9 gearbox and zetec engine to my Striker and have been looking at Starter Motors is the following suitable?
eBay - The UK's Online Marketplace
Just want to check before committing.
Mike
AndyG
posted on 30/3/12 at 01:58 PM Reply With Quote
I bought that starter motor from them a few months ago its not the same as the one in the photo but I still have it so I will try a post of photo of it tonight so you can see what you would be getting. It needs quite a bit of metal grinding away to get it to fit, therefore I found a slimer starter motor that required far less grinding that seemed to fit ok and works fine.
r1_pete
posted on 30/3/12 at 02:44 PM Reply With Quote
Try QX Components QS1221, mine was less than £50 delivered.
Pictures of it fitted in my archive under Engine...
AndyG
posted on 30/3/12 at 03:51 PM Reply With Quote
That's what I used as well, seemed to fit well.
dlatch
posted on 30/3/12 at 05:39 PM Reply With Quote
pete did you need to enlarge the mounting holes on that starter?
the main issue seems to be the sump fouling rather than anything else
r1_pete
posted on 30/3/12 at 06:01 PM Reply With Quote
No hole opening up, but, for any starter using this config on a blacktop you need to remove a lot of alloy from the intermediate sump. In the end I used a silvertop sump, it had a better profile, but still needed mods, I'm sure there are pics in my archive.
HowardB
posted on 30/3/12 at 06:58 PM Reply With Quote
I have a second hand one, and spacer ring if you need £20 + postage,... if that helps, or you can collect from Leicester or Biggleswade
Howard
