New Topic New Reply
Author: Subject: Brake Problem...Master cylinder??
vinnie_b23
posted on 5/4/12 at 05:56 PM Reply With Quote
Hi all,
I know this has probably been covered and i have tryed a search but its easier to ask sorry.
I've bled my brakes for hours as i though it was an air problem but i cant stress how long i've done it for to rule this out.
Anyhow my problem is the peddle will go hard after 3 pumps then when you release pedel the resovoir level creeps up and the pedel goes spongy, hiting the floor when pressed again.
Everything is new apart from the master cylinder which is an ap lockheed and the to rubber hoses going to front calipers but i cant detemine which is the fault. I know i need to clamp the pipes which i didnt think of doing and i know this will indicate but does anybody know off hand?
vinnie_b23
posted on 5/4/12 at 06:06 PM Reply With Quote
Sorry this should be in running gear
Ben_Copeland
If you've definately got all the air out then sounds like the master cylinder seal. Have you got all the calipers bleed nipple at the top?
Ben
Locost Map on Google Maps
Enter Your Details Here
vinnie_b23
posted on 5/4/12 at 06:14 PM Reply With Quote
Hey i've got a mate called ben copeland haha
On that bombshell no i havent, they are on the bottom. So i'll swap the calipers around, will this cure?
Also if it helps they are type 16 ford capri calipers.
[Edited on 5/4/12 by vinnie_b23]
nickharding
posted on 5/4/12 at 06:27 PM Reply With Quote
Hi mate,
Defiantly sounds like a master cylinder seal.
Nick.
Ben_Copeland
posted on 5/4/12 at 07:14 PM Reply With Quote
Small World,
On the bottom means you wont get the air out properly unless you take the calipers off when bleeding. Better to swap them all round so everything at the top. Rebleed and go from there...
Ben
daviep
posted on 5/4/12 at 07:55 PM Reply With Quote
Originally posted by nickharding
Hi mate,
Nick.
Please explain how you come to that conclusion? Doesn't sound anything like a MC fault to me.
Sounds like a perfect case of lots of trapped air, you pump the pedal and the gets compressed until it won't compress any more, then when you release the pedal the air acts like a spring and pushes all the fluid back to the reservoir as it expands again.
Davie
pmc_3
posted on 5/4/12 at 09:27 PM Reply With Quote
As said by ben above bleed nipples should always be at the top. I've made the same mistake before and spent ages trying to bleed it, as soon as I swapped the calipers over had it bled in about ten minutes!
vinnie_b23
posted on 5/4/12 at 10:32 PM Reply With Quote
Cheers guys, I'll try the calipers first thing tomorrow! I thought it would be something stupid but couldnt see anything obvious.
I've have literally spent hours bleeding these because i knew there was air somewhere and couldn't get my head around it.
nickharding
posted on 5/4/12 at 11:04 PM Reply With Quote
Missed the comment where the nipples were on the bottom. :O
vinnie_b23
posted on 6/4/12 at 09:49 AM Reply With Quote
Sorted it! changed the calipers around, bled it and pedal stays firm. Thanks alot people, was pulling my hair ot about this and was about to order new master cylinder and hoses.
Definatly wont be making this mistake again.
New Topic New Reply
