Author: Subject: 1700 x flow 244 kent cam
mexico72
posted on 7/4/12 at 08:46 PM Reply With Quote
HI, I've had no success in finding base carb setings for my 1300 x flow, that is all the excuse I need to fit my 1700 instead, spec as follows, stage 3 head, 1300 +90 thou high comp pistons with deeper pockets, kent 244 cam, duplex timing gear, lightened and balanced, twin (weber) 40 dcoe carbs, as this is a more common set up, can anyone help with jet sizes/set up for this just to get me started prior to final setting up on rolling road,
thanks in advance,
johnemms
posted on 7/4/12 at 10:35 PM Reply With Quote
Get some cheap micro drills off ebay ...
also use a digital micrometer to measure cheap drills for accuracy ..
You can now solder up the jets and re-drill to suit n get close..
Then eventualy off to the rolling road..
I got a BCF2 cam .. timing says 16 degrees static advance! go check your timing for your cam...
snapper
posted on 8/4/12 at 06:08 AM Reply With Quote
Turbosports forum will have the info you require for this setup
I eat to survive
I drink to forget
Dave Ashurst
posted on 8/4/12 at 08:48 PM Reply With Quote
Personally I wouldn't spend time and money on jetting it myself at all - if it runs, however roughly, book it in and drive it to a good rolling road place. If not then trailer it.
thunderace
posted on 8/4/12 at 09:34 PM Reply With Quote
http://www.burtonpower.com/tuning-guides.html
posted on 9/4/12 at 07:37 AM Reply With Quote
ISTR Dave Andrews? had a site that gave basic settings for Weber carbs when I was looking into them for my car . You might be better off using bike carbs or even throttle bodies . I went injection on my x flow , it drives so much better than any weber carbed car I have ever driven
