Author: Subject: oil pressure sensor
dan-g
posted on 8/4/12 at 02:47 PM Reply With Quote
oil pressure sensor
to add to the brake problems we have we also have an oil pressure problem!
the pressure sensor seems to be shooting out oil!
its thi s sender
1 wire connects to it but it seems the oil squirts out the connector! its a 1.8cvh out of a 1988 sierra
guessing we just need to replace the switch and work from there but i thought i'd ask and see!
thanks
ShaunB
posted on 9/4/12 at 10:33 PM Reply With Quote
Same sender is on my xflow and I had one start leaking as you describe. Replacement cured it.
Cheers, Shaun.
