Author: Subject: RT DASH 2 SPEED SENSOR
daniel mason
posted on 9/4/12 at 10:59 AM Reply With Quote
Anyone know which speed sensors can be used on dash 2? my dash went away for setup but for some reason the speedo isnt working still. so i tried to fit an extra washer as a spacer to close the gap a bit between prop bolts and sensor and it cliiped it as it rotated and snapped it
i have a spare but its not the same as the rt one i was using. im tepmted to cut the loom and wire the new one in to see if it will work!
simonwinn
posted on 9/4/12 at 01:32 PM Reply With Quote
Cant you use the sensor in the gearbox? Thats what I used on the Mojo with RT dash and Honda B16A2 engine.
beaver34
posted on 9/4/12 at 04:34 PM Reply With Quote
i use a halls sensor think mine was a etb one or something like that
has a light on the sensor on mine so you know when its close enough, run mine of the front hub using the 4 bolts as pickups
daniel mason
posted on 9/4/12 at 05:23 PM Reply With Quote
cheers beaver!
jeffw
posted on 9/4/12 at 05:47 PM Reply With Quote
any reason why you wouldn't use the RT one? http://www.race-technology.com/content.php?pcat=2&cat=61
daniel mason
posted on 9/4/12 at 05:48 PM Reply With Quote
yeah. they are expensive and for some reason the one i have is not working!
edit. cheers jeff.the one in your link is not the one i got with the dash! that looks fine cheers again
[Edited on 9/4/12 by daniel mason]
