Author: Subject: Reducing weight.
DANMAN
posted on 10/4/12 at 07:15 AM Reply With Quote
Reducing weight.
Hi guys.
I am looking at options to reduce weight on a Stuart Taylor BEC with a 918 (or 919 if you'd like) engine in it.
I have been looking into the lightweight lithium iron batteries as an option and I'm thinking of trying to reduce the weight by eliminating any wiring not required. I will probably change the front brakes (Escort I believe) to some Wilwood Dynalites at some stage also. Any other tips and tricks on reducing weight?
Dan.
[Edited on 10/4/12 by DANMAN]
Daily Driver - Audi A4 2L Turbo Quattro
Work Horse - Falcon XR8 Ute - Now Supercharged!
Rally Beast - 1972 Ford Escort 2L
Off The Road - Locost 2L Turbo (Z1 Concept)
Track Car - Stuart Taylor Blade
amalyos
posted on 10/4/12 at 07:32 AM Reply With Quote
Don't waste your money on the Lithium Ion battery.
One of the guys in the RGB series tried one, and had lots of problems with cranking and it may be a coincidence, but his Power Commander packed up. The thinking is it may have been a spike from the battery.
If you do decide to use one, you will need to pay for the special charger and charge it regularly, as we don't believe that the bike charge system is correct for this type of battery.
Willwoods all round are a good save, and also front alloy hubs.
Have a look at your uprights as well, if your uprights are Cortina based, MNR do a steel fabricated upright thats lighter than the Raceleader alloy ones.
[Edited on 10/4/12 by amalyos]
http://stevembuild.blogspot.com
cliftyhanger
posted on 10/4/12 at 08:14 AM Reply With Quote
Let's be realistic too. Think about how much weight you can save on the wiring. Maybe a couple of pounds max?? Be easier and more effective to drive naked. Concentrate on the heavy stuff, ie you, seats etc and then work your way down. There is plenty of wiring options too, thinwall etc that will help, but the gains will be tiny.
Also, have a look at wheels/tyres, unsprung weight is often overlooked. Smaller tyres can be much lighter.
ceebmoj
posted on 10/4/12 at 08:38 AM Reply With Quote
hi,
not a huge saving in its self but, one of the first jobs I did was to go round all the bolts on the car. Ensure that they where the correct length. This then got me looking more critically at everything witch has identified a number of items I will be spending more time on.
balidey
posted on 10/4/12 at 08:48 AM Reply With Quote
Semi-serious suggestion.
Go for a wee and a poo before you drive the car.
The weight saved will be about the same you can hope to achieve by other real world weight saving advice.
And its free.
personally I think very small weight savings are not really worth it. If you are saving grams then don't bother. A gust of wind on your journey will probably have more affect on the performance of the car.
Dutch bears have terrible skin due to their clogged paws
kjouk
posted on 10/4/12 at 08:49 AM Reply With Quote
Just being doing this to a westie, my list for attention was:
Smaller diff/better ratio which then allows for smaller tyres
Lighter paneling
Chassis changes/bracket removal
Smaller springs
Gear change mechanism
Seat Mounts
Silencer
Steering Column
Cooling
Net result was ~35kg loss at cost of ~£35/kg depending on how you account for some things like tyres which I wwas going to need to buy anyway. I made a lot of smaller changes as well but these in total account for <5kg.
Wadders
posted on 10/4/12 at 09:24 AM Reply With Quote
Junk the Diff brackets that STM supplied, they are heavy and crap, so two birds with one stone etc
Dunno what wheels you have on, but one of the biggest weight savings can be had by switching to lightweight 13" wheels.
If you're not racing, junk the roll bar and get one made in T45.
Alloy calipers all round, and smaller/lighter discs... Iv'e got bike discs on the back.
Alloy front hubs.
Al.
hughpinder
posted on 10/4/12 at 10:00 AM Reply With Quote
Whats sort of shocks have you got - if they're 2.25 inch steel, going to 1.9" alloy ones will save quite a lot.
Regards
Hugh
matt_gsxr
posted on 10/4/12 at 10:03 AM Reply With Quote
Maybe he is already driving naked.
Top of the list are good £/lb, bottom are expensive
ditch the toolkit
pc680 battery (~7kg)
13inch wheel with light tyres (9kg per corner)
lose the windscreen, wipers, heater, heavy seats
Smaller tank with less spare fuel (10kg)
Lighter silencer
Trim bolts down (low cost, but pita)
6.5inch diff instead of 7 or (heaven forbid) 7.5inch
Alloy front hubs
Alloy brake calipers (save you maybe 1-2kg per corner)
Alloy rear bearing carriers
Custom driveshafts
Fill tyres with Helium
titanium bolts
I'd be interested in what £/lb people are prepared to spend to lighten their cars.
DANMAN
posted on 11/4/12 at 01:16 AM Reply With Quote
- Well, I only drive naked during summer so that's out
- Pees and Poos sound easy enough
- I will probably convert the rear drum setup to disc. Does anyone know what Disc to use and which Wilwood rear calipers to use? Also which Wilwood front calipers will fit?
- It has an 11L alloy fuel tank already fitted so I may stick with that and it also has a lighter silencer fitted although I might try to find a carbon fibre jobbie or titanium
- It has no windscreen so I don't need to worry about that
- I will trim down any overly long bolts and change any steel brackets for alloy ones (unless they are structural)
- I will remove the seats and see what they weigh and replace with lightweight options if necessary
- The wheels on it are apparently lightweight ones (Mk1 RS Escort four spoke looking things) although I am thinking of changing to some minilites
- I'm using alloy seat mounts in my other Locost so I will do the same in this one if they're not already alloy
- I will probably still do the wiring as I did save about 3kgs in my other Locost when I did it but the guy that built it had used a wiring loom from a Mitsubishi Starion! I am also going to ditch some of the gauges I don't require and make a new lightweight dash
- I am going to race it so I will probably use the existing roll bar but I havn't ruled out going to Chromoly
- I am going to change the gearshift from lever to paddle style, not sure if I will save any weight there or not, I wouldn't think so but I'll be doing it regardless
Any idea where to get the replacement diff brackets from so I can ditch the STM ones?
I'm also curious about the bike rear disc option. Is there a kit available or do you have any info/pics on what you have done?
Any links to where I can get the lightweight alloy hubs, uprights, shocks, etc?
Sorry for all the questions. I have only just bought the car and this is all quite new to me
Dan.
DANMAN
posted on 16/4/12 at 05:13 AM Reply With Quote
Does anyone know what the standard Escort Mk2 uprights and hubs weigh?
