TimEllershaw
posted on 19/4/12 at 05:35 PM |
Acewell 3252 - Reset ?
Does anybody know how to reset the mileage on an Acewell 3252 speedo ?
I thought I could set the ODO to match the speedo I've taken out, but can't seem to find it.
Probably because I screwed up the initial calibration and it thought I was travelling at ridiculous speeds all the time and now thinks I’ve done loads
of miles. I think it allows you to change the mileage when you first install it, but now can’t find it on the menu.
Would also be good to reset the gear indicator, ( calculated from engine rpm and speed when first installed ) so always shows the wrong gear now.
If I can’t reset the ODO, do you think the MOT man is going to care ?
Thanks,
Tim.
http://www.teenagecancertrust.org/
Werner Van Loock
posted on 19/4/12 at 06:26 PM |
Can't reset it past 30 miles (or something like that). It's like that with all acewells.
http://www.clubstylus.be
