ChrisW
| posted on 29/8/04 at 10:51 PM |
MT75 'box from a 4 pot
As subject really! I'm after an MT75 taken from a 4 cylinder Sierra, I'm guessing a 2.0 Pinto, if such a thing exists.
Anyone got anything? Closer and cheaper the better!
Chris
twinturbo
| posted on 30/8/04 at 10:20 AM |
All post 1990 ( and some mid 89 on ) 2.0 sierras ar DOHC they are teh only 4pot engines that got the MT75.
Pinto used the Type 9
There's lots about these days...
I am assumiong you do actualy want this box...
What are you mating too?
TT
ChrisW
| posted on 30/8/04 at 10:32 AM |
2.5 V6 Duratec, although I'm yet to find out for sure if the bolt pattern is the same. They normally come coupled to the MTX75 box which is
also used on the 2.0 Zetec in a Focus so I'm assuming (hopefully correctly) that as the Zetec bolts straight up to the MT75 so will the
Duratec.
If anyone knows any different please say!
Chris
phelpsa
| posted on 30/8/04 at 11:49 AM |
Are you putting a Duratec V6 in the Viento?? It is a very nice sounding engine, my dad had 2 V6 mondeos.
Adam
Serial car dismantler....
GSXR1100 engined IRS Locost, '89 205 Roland Garros,
twinturbo
| posted on 30/8/04 at 01:27 PM |
No idea if the Bolt pattern on the MTX and MT are teh same I am affraid..
How you going to mount the Duratec, As I understand they have no points to attatch engine mounts on teh sides of the block.
TT
ChrisW
| posted on 31/8/04 at 10:52 AM |
It's not going in the Viento I'm afraid! Just collecting bits for another conversion but it is a long way off yet
Chris
Graceland
| posted on 1/9/04 at 09:31 PM |
bolt pattern is the same on the MTX and MT75
look at it this way rob
RS2000 escort - uses same block as sierra dohc, sierra dohc uses MT75, rs2000 uses MTX75
ahhhhhhhh - i love been right for once lol
For the ride of your life, Sleep with a train driver
heyzee
| posted on 3/9/04 at 06:06 PM |
mt75
i have one mate but your miles away
twinturbo
| posted on 3/9/04 at 09:55 PM |
Smart A..s Paul
But is the Duratec V6 MTX75 the same as the 4pot MTX75?
Or are ford just as helpful as they are for us poor Cologne V6 boys..
TT
ChrisW
| posted on 5/9/04 at 07:16 PM |
This is what I'm trying to find out...
What I do know is the 2.0 Zetec Focus also uses the MTX75 box and that engine will bolt to an MT75. No one has been able to tell me for sure if
it's the same so I think I might have to buy one and find out.
Chris
phelpsa
| posted on 5/9/04 at 07:40 PM |
Or find someone who'll lend one to you???
Adam
ChrisW
| posted on 5/9/04 at 09:51 PM |
Lend me an engine?? Can't see that happening when they find out I need to take the gearbox off and try to fit my own!
Chris
theconrodkid
| posted on 6/9/04 at 08:09 AM |
make a patern from a sheet of card etc and post it?
who cares who wins
pass the pork pies
twinturbo
| posted on 6/9/04 at 01:24 PM |
Part number for the casing are different
TT
ChrisW
| posted on 6/9/04 at 10:42 PM |
Would that be because the Mondeo V6's were 6 speed?
Chris
Mikey G
| posted on 6/9/04 at 11:24 PM |
All V6 mondeos up untill the ST220 where 5 speed MTX75
Just to put a spanner in the works, early cossie engine based on pinto used T5 box, later 4x4 (still pinto pattern) used MT75, plus cossie has been
fitted to MTX box for transverse aplication!
Mike
ChrisW
| posted on 8/9/04 at 10:03 AM |
Just going to have to get one and try it arn't I! I have an old type 9 bellhousing in the garage so I'll assume if that bolts up then the
MT75 will.
Been offered a 100,000 mile engine for £100. It'll need the pistons changed anyway so I'm not too bothered about rebuilding it. Reckon
it's worth a shot?
Chris
timf
| posted on 8/9/04 at 10:50 AM |
rebuild parts for a 2.5 v6
only one ford list
new engine no bearings etc
thats why there are somany about on ebay etc cheaply.
ned
| posted on 8/9/04 at 10:56 AM |
i'm sure someone like burtons or mountune can supply the necessary bits. i know mountune build race engines out of the duratec v6, so they must
get replacements bits from somewhere..
Ned.
beware, I've got yellow skin
timf
| posted on 8/9/04 at 11:03 AM |
Ned.
mountune have the parts made special at very high cost.
ned
| posted on 8/9/04 at 11:36 AM |
you must be able to match the bore/deck piston height to another engine, then get rods made up to suit. it's probably the bearings and timing
gear that are more expensive to get made in small quantities..
Ned.
[Edited on 8/9/04 by ned]
twinturbo
I can also confirm ford list service replacement engines only.
TT
ChrisW
| posted on 9/9/04 at 09:41 AM |
The Duratec is used as a turbo in the Nobel so the low comp pistons must be available for it. It's just finding a set...
But, as suggested, I'm planning on trying to match them to another engine and then figure out how to attach them to the rods. Another long term
project!
Chris
[Edited on 9/9/04 by ChrisW]
Liam
| posted on 22/9/04 at 07:46 PM |
Might be out of date now, but I'll add my 2p. I'd be very surprised if the duratec and 4-pot bolt patterns are the same. You'll
probably find that ford have a bolt pattern for all 4-pots (hence all the 4-pot MT75 and MTX75 interchangability) and a different pattern for v6s, as
is the case with the cologne. Whether or not cologne matches duratec, who knows? If you get a duratec, I have a cologne bellhousing you can easily
try on.
Thinking about it, the 4-pots all have flanges on the side of the block where you bolt from the engine side into threaded holes in the box. Obviously
a v6 can't have this arrangement and all bolts go from gearbox side to engine. This points to the likelyhood of your particular mating attempt
being unsuccessful =(.
Yo
Liam
ethomas
| posted on 10/3/05 at 11:15 PM |
Did this ever get settled
Did you find out whether this was possible? I am asking because my long term plan, once the 1600 pinto has got me through the SVA test, is to fit my
Eagle with something with a little bit of grunt - the car looks like something that should have a lot of cylinders under the bonnet, but I want to
stay nice and light so a 2.5 duratec would be perfect.
Ed
