Author: Subject: durance fuel pressure regulator
shirt
posted on 26/4/12 at 08:44 PM Reply With Quote
hi guys,
i've bought an adjustable fuel pressure regulator from burton power, same as this one:
http://www.burtonpower.com/parts-by-category/fuel-system/fuel-regulators-injection/wfr505.html
with a standard inlet manifold, the small silver tube would be connected via a hose to a port on the manifold for reference pressure. my manifold is a homebrew so i'm wondering what to do with it. a mate with a duratec'd mk2 escort has his going into a small, sealed, plastic container. is what i'm after a vacuum pressure like this?
any suggestions?
big-vee-twin
posted on 26/4/12 at 09:25 PM Reply With Quote
Do you have a vacuum connection for a MAP sensor, if so run this to a small plastic container and form a vacuum plenum and then create two connections from it one to the MAP and the other to the regulator.
http://www.triangleltd.com
shirt
posted on 29/4/12 at 07:16 AM Reply With Quote
i don't think so. the manifold is a very crude homebuilt affair made by the previous owner - one large dia. tube with 4 ports going to the head, one end blanked, the other connected the the throttle/air filter assy. it has a throttle position sensor and one embedded in the filter which i assume to be the MAF or inlet temp sensor.
haven't got to grips with what ECU its running yet, just driving it until i accumulate the rest of the bits i need to fit the jenvey's that came with it.
would putting a hose just between the reference port on the FPR and a sealed plastic container work? what is the effect of running without the reference pressure hose?
BaileyPerformance
posted on 1/5/12 at 03:39 PM Reply With Quote
I would leave the vac port disconnected if i was you, no real need to have it connected to the manifold. Assuming your ECU is aftermarket it can be re-calibrated to suit, you will need to do this anyway if you modify the car further.
