<<  1    2  >>
Author: Subject: get around IVA
puma931
posted on 4/5/12 at 10:55 AM Reply With Quote
get around IVA
Is it possible to buy an old but registered kit car and trasfer the plate/chassis number to a newly build kit and then put it on the road?
Bluemoon
posted on 4/5/12 at 11:00 AM Reply With Quote
No... Well unless you use enough of the old components on the "points" system..
[Edited on 4/5/12 by Bluemoon]
puma931
posted on 4/5/12 at 11:01 AM Reply With Quote
No...
Why not? I ve seen loads of 1960's minis running arround in new shells...
Bluemoon
posted on 4/5/12 at 11:03 AM Reply With Quote
A new shell is o.k depends on "points" i.e. need receipt of chassis built to the original design.
Proby
posted on 4/5/12 at 11:06 AM Reply With Quote
Of course you can! It's known as a false identity! And not far off the lines of ringing (apart from the stolen car bit), very dodgy, but you must know that surely?
And a mini that you mention is a reshell, not buying a new mini and banging on the chassis/reg number???
[Edited on 4/5/12 by Proby]
puma931
posted on 4/5/12 at 11:10 AM Reply With Quote
Thats what I thought, but IMO only "slightly dodgy" if you buy and own both cars and destroy the old car afterwards, plus it still has to get an MOT.
computid
posted on 4/5/12 at 11:15 AM Reply With Quote
It is possible, but very illegal and VERY frowned upon by everybody else in the kit car community. Not only because you are stripping an old kit car of its identity but because you are driving a mis-registered vehicle on the road.
Its like me building a seven out of a sierra and then slapping the sierra plates on it and driving it around. It's illegal. It used to happen a lot because it was unlikely you were going to get found out but nowadays with ANPR its highly likely you'll get found out and have your vehicle confiscated.
The only reason it MIGHT work with a kit car is because most traffic cops wont know the difference between a rickman ranger and a locost but if you get the one that does then your screwed.
I believe (and I could be wrong) that the punishment for having a mis-registered vehicle is confiscation of the vehicle and a £1000 fine. Not really worth it IMHO.
computid
posted on 4/5/12 at 11:16 AM Reply With Quote
Oh yeah, and you might have some trouble with that too if the tester knows his kit cars and wants to cause you some pain.
gdp66
posted on 4/5/12 at 11:18 AM Reply With Quote
If you buy an old locost or any 7 type car which is road registered.
Why can't you repair /replace with a new chassis and swap all of the parts over.
if you cut up the old chassis, whats illegal ?
puma931
posted on 4/5/12 at 11:19 AM Reply With Quote
OK, thanks for the advice, I think I will prep the car for IVA.
designer
posted on 4/5/12 at 11:20 AM Reply With Quote
"slightly dodgy"
Is there any type of 'slight' crime?
It's cheating!
A1
posted on 4/5/12 at 11:22 AM Reply With Quote
but if its the same car its coming off...ie an old crashed robin hood going onto another robin hood...
im not condoning or anything...
[Edited on 4/5/12 by A1]
puma931
posted on 4/5/12 at 11:23 AM Reply With Quote
Originally posted by designer
"slightly dodgy"
It's cheating!
Even if it is an old locost?
A1
posted on 4/5/12 at 11:24 AM Reply With Quote
beat me to it
gdp66
posted on 4/5/12 at 11:27 AM Reply With Quote
That was my point.
If you crash your Tiger/MK/GKD/Westfield/Caterham, you send it back to the manufacturer
They say it needs a new chassis. They rebuild it. It won't go for another IVA.
Whats the difference with picking up an old locost, which is correctly registered, and using another locost chassis to fix/rebuild
pdm
posted on 4/5/12 at 11:30 AM Reply With Quote
Originally posted by gdp66
That was my point.
Yes but it will go for a VIC check wouldn't it ?
Bluemoon
posted on 4/5/12 at 11:33 AM Reply With Quote
That was my point.
You can't do that with an "old" chassis but if a "new one" direct from the manufacture and so long as you can get 8 points:
http://www.direct.gov.uk/en/Motoring/BuyingAndSellingAVehicle/RegisteringAVehicle/Registeringakitcarrebuildorradicallyalteredvehicle/DG_191068
Now for a locost the manufacturers will be the original builder if home build chassis or a manufacture if bought.. or could any home constructor be a manufacturer??? That's probably the gray area...
Dan
nib1980
posted on 4/5/12 at 11:36 AM Reply With Quote
dont forget the IVA isn't just a tick box excercise , it's to make sure the vehicle is safe to be on the road. it's far more stringent than an MOT.
you can be the best engineer in the world, but you may have missed something or made a mistake that could kill you or other roads users.
blakep82
posted on 4/5/12 at 11:42 AM Reply With Quote
haven't read through all the replies, but i can pretty much guess what they all say.
no, taking an old car (duttons are common) and stamping the chassis number and reg numbers and putting them on your new, or ex-race car (if i remember right) is illegal, its fraud, etc
however, taking say a caterham which has been damaged with a bent chassis, or a mini which is rusted, and replacing the chassis, WITH AN IDENTICAL ONE FROM A RECOGNISED MANUFACTURER (caterham or british motor heritage ltd in both of those cases) and transfering the chassis numbers is ok, as its just repairing the chassis, and a striaght chassis replacement.
HOWEVER! replacing a mini shell with a new carbon shell and transferring the numbers would not be allowed, as the original chassis wasn't carbon
somewhere in the middle must be a grey area, but what you're saying, ie to avoid IVA, is illegal, and may void your insurance if you have a crash and the car is inspected by someone who knows his stuff
[Edited on 4/5/12 by blakep82]
________________________
puma931
posted on 4/5/12 at 11:46 AM Reply With Quote
OK. Understand.
Dick Axtell
posted on 4/5/12 at 02:46 PM Reply With Quote
however, taking say a caterham which has been damaged with a bent chassis,..........., and replacing the chassis, WITH AN IDENTICAL ONE FROM A RECOGNISED MANUFACTURER..............and transfering the chassis numbers is ok, as its just repairing the chassis, and a straight chassis replacement.
This is exactly what happens with Land Rovers. Indeed, there are engineering outfits which specialise in LR chassis replacements, and they don't have to undergo IVA test. Because the chassis comes from the original manufacturer, it has already undergone type approval testing. I've seen a 1963-reg Landie, sporting radius bars + coil spring suspension (i.e. Defender style), and these were definitely not around in the early 60s versions. Older LRs carried the traditional live axle-on-cart-springs arrangement.
(We tried out independent suspension on another 4x4, using Flexitor suspension arms. Insufficient traction for dealing with off-road conditions!!!).
emwmarine
posted on 4/5/12 at 02:55 PM Reply With Quote
And in the land rover world the forums are full of newer land rovers being passed off as older ones (to avoid car tax) being reported to DVLA.
Building a Dax Rush.
Dick Axtell
posted on 4/5/12 at 03:55 PM Reply With Quote
That's news to me! And helps to clarify things, slightly. Which probably explains why I haven't seen that 63-reg LR around so recently. On the other hand, if the DVLA is happy for the re-chassis-ed vehicle to continue carrying its original reg, why shouldn't the owner continue claiming pre-1972 road tax qualification?
billy
posted on 4/5/12 at 05:39 PM Reply With Quote
You could ways get hold of a dutton logbook! I'm sure lots have
luego-lo-cost finished,vauxhall 16v 2.0,twin 45s de-dion rear set up
MakeEverything
posted on 4/5/12 at 05:51 PM Reply With Quote
Lets not lose sight of the purpose of IVA, Safety.
Kindest Regards,
Richard.
<<  1    2  >>
