ChrisW
posted on 9/5/12 at 12:12 PM |
Brake ideas for my Scooter
Sorry everyone, more scooter related questions!
For those that don't know the story so far it's a mobility scooter chassis with 110cc pit bike engine running a rear axle from a kart.
I'm trying to work out what to do about brakes. A kart brake caliper would be the obvious solution, but they're designed to work off a
pedal whereas I want motorbike-style handlebar brakes. Now I guess I could use a motorbike hydraulic lever, but I can't find any information on
master cylinder sizes and have no idea whether this would produce a sensible amount of braking effort.
So then I looked at motorbike calipers, but it seems bike discs are thinner than the 12mm that I have on the kart axle, so I'd have to adapt a
motorbike disc to fit the kart carrier. Sounds like a nightmare.
Does anyone have any pointers or bright ideas?
Thanks, Chris
My gaff my rules
nige
posted on 9/5/12 at 01:40 PM |
what about pit bike or small 50cc scooter brakes
are they too big ?
when you start this journey
you think it will be done in " no " time but then " no " turns into a " bloody " long time
ChrisW
posted on 9/5/12 at 02:01 PM |
They won't take the 12mm thick disc, so I'd have to try to fit a thinner disc to the kart axle carrier.
Chris
My gaff my rules
v8kid
posted on 9/5/12 at 02:19 PM |
It's quite cheap to get discs turned down I got a pair reduced to 10mm, drilled and the pcd altered for £30. Apparantly most time is spent
setting them up on the lathe and thats where the cost is.
You'd be surprised how quickly the sales people at B&Q try and assist you after ignoring you for the past 15 minutes when you try and start a
chainsaw
designer
posted on 9/5/12 at 02:22 PM |
Don't some mountain bikes have hand operated disc brakes?
ChrisW
posted on 9/5/12 at 02:28 PM |
The problem with doing that is that it's a vented disc, so if you turned it down to 6-7mm you'd be left with the space in the middle!
As for mountain bike brakes, I suspect the same problem. That's if they were even man enough for the job which I doubt!
Chris
My gaff my rules
maccmike
posted on 9/5/12 at 02:40 PM |
I use a front brake caliper off a pit bike. Disc is a gsxr1100. Cool thing is as its a mechanical cable operated caliper, Iv spaced it and used longer
bolts to accommodate thicker disc. Cost me about 12quid off ebay.
ChrisW
Sounds interesting! Any chance of a photo?
Chris
My gaff my rules
JAG
posted on 9/5/12 at 02:41 PM |
How heavy will the whole thing be with you onboard?
How many discs will be on the vehicle?
Justin
JAG
ooops double post
[Edited on 9/5/12 by JAG]
Justin
Chippy
posted on 9/5/12 at 02:43 PM |
Aren't all callipers made in two parts, and if so can't you just make up a spacer plate to make the calliper fit the disc, seems like a
plan, :-) Cheers Ray
Must type faster. Ho Hum!
[Edited on 9-5-12 by Chippy]
Fred W B
posted on 9/5/12 at 03:25 PM |
Older karts used cable operated brake calipers
Fred W B
posted on 9/5/12 at 03:29 PM |
Just rub your shoe on the wheel to slow down - that's what the kids round here do after they've removed the brakes from their BMX bikes
ChrisW
posted on 9/5/12 at 03:48 PM |
I'd guess it's going to be the best part of 150kg with my fat arse on board. There's a single disc on the rear axle.
Chris
My gaff my rules
Dangle_kt
posted on 9/5/12 at 05:49 PM |
Mini Moto caliper, cheap, cable operated, same lever as a push bike too
ChrisW
posted on 9/5/12 at 08:26 PM |
Can they be spaced out to fit the kart disc?
Chris
My gaff my rules
