Author: Subject: Excel formula?
posted on 25/5/12 at 11:34 AM Reply With Quote
Excel formula?
I need a formula for adding up hours..
Say I list start and finish times, minus any breaks...
Start 14.00
Finish 01.30
Break -45
What is the formula to give me the correct, 10.45m?? I've tried the time settings in the formet cells box but all it seems to do is 00.00.00 and the -45 gives me an input error.
Any ideas??
Its for an invoice by the way
designer
posted on 25/5/12 at 11:57 AM Reply With Quote
You can format the cells to time, then a normal formula (+,-,X) will work out the hours.
rachaeljf
posted on 25/5/12 at 12:05 PM Reply With Quote
I do something similar to automate timesheets. Convert your hours to decimal hours (e.g. 01.30 = 1.5 hours), do your sums, then convert back. You will need the INT function and an IF statement to add 24 hours to your finish time if it is less than your start time. If you really want, you can make your times display a colon separator rather than the decimal point. Hmm, colon separator, sounds nasty.
Start time: =INT(start)+(start-INT(start))/0.6 - edited for typo!
Finish time: =INT(end)+(end-INT(end))/0.6+IF(end<start,24,0)
Sum: =end-start+break/60
Output in decimal hrs: =INT(sum)+(sum-INT(sum))*0.6
or Output in h:mm : =TEXT(sum/24,"h:mm")
Cheers R
[Edited on 25/5/12 by rachaeljf]
daviep
posted on 25/5/12 at 12:06 PM Reply With Quote
The problem is trying to do it over midnight - I was feeling quite clever until I plugged coozers actual time in and it threw a hissy fit
Davie
cerbera
posted on 25/5/12 at 01:02 PM Reply With Quote
For it too work overnight you need to put the start date and time in one cell and the end date and time in another then simply subtract the cells and subtract the break.
eg
Cell A1 - Start Time
01/01/2012 14:00
Cell B1 - Finish Time
02/01/2012 01:30
Cell C1 - Break
00:45
Cell D1 - Total Hours Worked
=B1-A1-C1
Format Cell D1 to show hh:mm
[Edited on 25/5/12 by cerbera]
Agriv8
posted on 25/5/12 at 01:46 PM Reply With Quote
yep I agree you are only going to get this to work placing the date at the front but if you are doing theis daily prefill the dates by entering 01/01/2012 00:00 , 02/01/2012 00:00 , 03/01/2012 00:00 ...... in column a and 02/01/2012 00:00 , 03/01/2012 00:00 04/01/2012 00:00 ........ in column b you then just need to change the 00:00 to your time
PS think it need to be : so it knows its a time
Agriv8
rachaeljf
posted on 25/5/12 at 02:04 PM Reply With Quote
:sigh: I suppose people see a female name at the top and don't look at the post!!!
Slimy38
posted on 25/5/12 at 02:08 PM Reply With Quote
Don't worry about it, there's been occasions where I've posted something then someone else has pretty much posted the same solution. We all seem to have 'invisible days'...
Dangle_kt
Eh?
I'm pretty sure no oneeven noticed your name.
rachaeljf
posted on 25/5/12 at 03:03 PM Reply With Quote
Easy Dang, only kidding!
Jaybeee
posted on 25/5/12 at 09:18 PM Reply With Quote
We use Excel for our timesheets at work I can have a look for you on monday if its not too late. I know we have a custom setting in the cell formats for when the time goes over 24hrs.
Let me know if you want me to have a look.
rachaeljf
posted on 25/5/12 at 09:59 PM Reply With Quote
Blimey, it really must be invisible day for me!
Above I have actually reproduced the Excel formulae to manipulate Coozer's input exactly as he typed it. It's much easier to enter times as HH.MM as if they were a decimal number as it just needs one hand on the numeric keyboard (other hand thus remains free for spannering or the activity of your choice). With the formulae above there's no need for special formats or having to enter the full date and time. If your finish time is "earlier" than your start time, i.e. you have gone into the next day, the formula adds 24 hours to the finish time.
Coozer - Enter your data off to the side of your printed invoice and use the TEXT(cell/24,"h:mm") function as above to display your entered times and output as properly formatted "HH:MM" with the colon separator on the printed invoice. The above formulae are what I use with the various different styles of client timesheets and my invoices.
Edited to disable smilies!
Cheers R
cerbera
posted on 25/5/12 at 11:08 PM Reply With Quote
Someone say something?
rachaeljf
posted on 25/5/12 at 11:15 PM Reply With Quote
Aggghhhh!
cerbera
posted on 26/5/12 at 08:48 AM Reply With Quote
To be fair Rachael I didn't actually understand your solution as I don't know excel that well so only offered a way I knew.
gingerprince
posted on 26/5/12 at 09:24 AM Reply With Quote
Lol, this thread reminds me of http://www.youtube.com/watch?v=DE3r_CgScms
