Author: Subject: Clear Out (phase 1) - MORE TO FOLLOW
82 Locost
posted on 25/5/12 at 07:34 PM Reply With Quote
Some parts from my garage, postcode YO30 2AA just North of York. I work at Lytham (nr Preston) if that's better for viewing/collection.
Please let me know if the prices are wildly off.
Item 1. Escort Halfshaft 22 splines
Good condition - bearing good.
£40 collected
Item 2. Escort Halfshaft 22 splines
£40 collected
Item 3. Escort Halfshaft 22 splines
Good condition - bearing slightly grumbly, but useable.
£40 collected
Rear Brakes - 8 inch
Used, but still good. One drum had been hacked about to get it to fit over a halfshaft. Drums still have a lot of life left. Changed these for 9" ones, otherwise I'd have kept using them. PRICED TO SELL because they're taking up space!
£20 collected
Front Calipers
Again, these are use but changed for new ones that came with new disks, otherwise I'd have kept using them. I'm sure they're fine, but selling as requiring a refurb. PRICED TO SELL because they're taking up space!
£15 collected
Radiator
Brand new, but with storage marks. This was kept as a spare that I never got round to using. Has a screw cap and overflow and modified inlet/outlet pipes (90 degrees off)
£35 collected
Escort Steering Rack
Again, an unused spare. 3.4 turns lock-to-lock and appears to be a refurb. Complete with track rod ends.
£40 collected
MORE TO FOLLOW, including
3.9 diff, 3.54 diff, 4.41 diff
1300cc +60" short engine
1300 heads
+90 pistons
+60 pistons
1300cc cranks
Cosmo mig welder, CO2 bottle and mask
1300 oil pick-up
Axle case
Yellow genuine Westfield bonnet
[Edited on 25/5/12 by 82 Locost]
82 Locost
posted on 28/5/12 at 11:31 AM Reply With Quote
Any offers?
jonrotheray
posted on 28/5/12 at 01:00 PM Reply With Quote
Definitely interested in a 3.54 diff.
Jon
82 Locost
posted on 28/5/12 at 01:50 PM Reply With Quote
I'll put the other bits in a post on Friday (when I get back home) with some pics. I need to confirm the condition of everything first.
[Edited on 28/5/12 by 82 Locost]
82 Locost
posted on 29/5/12 at 08:19 AM Reply With Quote
Driveshafts now £30 each, can do a deal for all 3.
Steering rack now £35
basford
posted on 29/5/12 at 04:37 PM Reply With Quote
What's the bonnet Wide or Narrow?
cheers
locost47
posted on 29/5/12 at 05:38 PM Reply With Quote
bits
hi are pistons new or used & 4.1 diff interested in both
82 Locost
posted on 29/5/12 at 09:27 PM Reply With Quote
The bonnet is narrow. I have been told it may be a pre-lit Westfield one. It has a Westfield manufacturers label on it.
Dimensions:
Length 99cm
Width at rear: 96.5cm
Drop at rear: 18cm
Width at front: 70cm
Drop at front: 16.5cm
Overall good condition, but with some minor damage, most notably at the front corners. Paint in good condition. £35.
The pistons are used. The +90 ones are in very good condition but have no rings. The do have gudgeon pins and circlips. Pics to follow on Friday. 3 of the +60 ones are in good condition, one has dragged on the skirt, so is probably no good. Pics on Friday.
basford
posted on 30/5/12 at 09:01 AM Reply With Quote
Can first dibs on the bonnet, just need to double check the size.
theduck
posted on 6/6/12 at 06:56 PM Reply With Quote
Would you post the drums? If so how much delivered?
82 Locost
posted on 6/6/12 at 07:04 PM Reply With Quote
Do you mean just te drums or the whole rear brake set-up?
I'm back at home on Friday so I can weigh them then and get you a price.
theduck
posted on 6/6/12 at 07:37 PM Reply With Quote
Whole setup. I think I have a mismatched setup docs known good one could be the answer.
