Author: Subject: Anyone using old type Emerald M3D??
dollie007
posted on 5/6/12 at 12:38 PM Reply With Quote
is anyone running the old-type (black body with round plug) Emerald M3D?? I'm really struggling to find a wiring diagram that matches mine and want to know it will run my pinto on GSXR TB's before I get too involved...
any and all help greatly appreciated,
Oliver
austin man
posted on 5/6/12 at 12:46 PM Reply With Quote
Email Dave walker hes not a bad chap and would probably email you one
dollie007
posted on 5/6/12 at 01:24 PM Reply With Quote
I've got a couple of different diagrams from emerald but none that seem to directly correspond with my ecu and don't want to badger them just yet as may need more info at a later point, but that may be the only option!!
[Edited on 5/6/12 by dollie007]
striker-4age
posted on 5/6/12 at 03:58 PM Reply With Quote
hi m8. i run one of these on my 4age sylva striker with gsxr t/b so yes it will do the job
dollie007
posted on 5/6/12 at 04:36 PM Reply With Quote
I think this ecu was previously on a 4age, but I'd like to use it on my pinto with GSXR tb's so that may help me answer a few questions if possible...
do you run a ignition module/amplifier on yours or wasted spark?
do you use a magnetic crank trigger?
do you have a wiring diagram??
thanks a lot,
Oliver
striker-4age
posted on 5/6/12 at 04:55 PM Reply With Quote
hi oliver
yes mate i do have a wiring diagram somewhere..............i will look for it
the ecu does the sparking and i dont have a crank trigger
what is your email address for when i fing the wiring diagram mate ?
striker-4age
dollie007
posted on 5/6/12 at 05:00 PM Reply With Quote
thanks a lot, that would be very helpful, email is oliverjl@hotmail.co.uk
how does yours know crank position/engine speed then?
striker-4age
posted on 6/6/12 at 08:52 PM Reply With Quote
hi oliver
i cant get my bloody scaner 2 work
list of wiring colours:
tacho b yellow
throtlle pot red +, green 0, black -
shift light white, and also +12v via fuse
dizzy orange (use in place of red + if hall effect), red +, blue 0, black -
battery black or good earth
ignition switch + red to ecu via 5a fuse
coil c green -
coil c red+ via ignition switch
hope this helps you out ?
give me a shout if you need more ?
striker-4age
dollie007
posted on 7/6/12 at 07:34 PM Reply With Quote
Hi thanks, yes that partly helps,
I have a list of pinouts that seems to tally with power/injectors/tacho etc, but I'm mostly confused about the green for the coils (my ecu has 2 larger green wires coming out, pins 'D' an 'R' iirc, and only 'D' is listed as a coil feed),
and also which wires I need for my trigger sensor, I don't really want to use the distributor, hoping to use the 36:1 trigger wheel I've fitted, but sounds like yours might be wired a bit differently?
thanks again
FatChapChipChop
posted on 18/6/12 at 09:37 AM Reply With Quote
Just a comment .. A Pinto dizzy from an injection car is good as a trigger reference as there's no advance spring / weights .. Fixed rotation so you can set the hall effect in the dizzy to 60 degrees BTDC. Emerald manual shows this setup nicely. And, you still use the dizzy for the sparks (or go wasted spark if you want).
Keeps things simple and works well ...
Oh, and don't worry about badgering Dave or Karl (Paton) at Emerald, they are always happy to help ...
Cheers !!
Drive fast, don't look back!
