Author: Subject: Vodou Auto Kits
Padstar
posted on 6/6/12 at 06:17 PM Reply With Quote
Vodou Auto Kits
Just stumbled across this site which has amended the original roadster design to suit the MX5 donor vehicle and in doing so incorporates the mountings and bracketery to suit the parts from the MX5 whilst trying to reduce the weight slightly.
Have any of you used their chassis plans?
They seem like a very professional set up with fully CAD'd drawings etc for the chassis construction.
If any of you have used it have you done so with the Mk1/2 MX5 or the latter Mk3?
ashg
posted on 6/6/12 at 06:50 PM Reply With Quote
i believe they planned to start producing roadster parts but never really got off the ground. there have been discussions on this forum and the haynes forum regarding the vodou plans vs the saturn plans. Search is your friend
Haynes Roadster (Finished)
Exocet (Finished & Sold)
New Project (Started)
Slimy38
posted on 6/6/12 at 07:24 PM Reply With Quote
Ah yes, I tried registering at that site to download the plans and see what they did, but I never actually managed to register and get logged in!
I've just tried again, first my password isn't being accepted and now I've tried their reset password and can't get anywhere with that either.
Shame really, I'd have liked to see what they've done.
Padstar
posted on 6/6/12 at 07:48 PM Reply With Quote
if you send me your email address i will forward the drawings on. They are really quite good.
Slimy38
posted on 6/6/12 at 08:25 PM Reply With Quote
U2U sent, thanks!
Padstar
posted on 7/6/12 at 09:34 PM Reply With Quote
Will email over the weekend as they are at home on the desktop.
Padstar
Slimy38
posted on 8/6/12 at 07:29 AM Reply With Quote
That would be excellent, thank you.
Padstar
posted on 6/10/12 at 01:33 PM Reply With Quote
Can someone please help me with a Vodou query.
I am using the voodoo plans to build the chasis for my MX5 based Haynes roadster.
I have a query on part LR13 & LR14. On the chasis drawing LR13 appears to be longer than LR14 but on the details the opposite is the case.
I have cut to the dimensioned details but before i weld can you confirm if this is the case (ie the engine mounts sit closer to LR10 than LR13).
Would hate to do a load of work and then be forced to alter it later.
Padstar
posted on 24/10/12 at 09:49 PM Reply With Quote
Bump. Please need help. Plan to start welding this weekend
mookaloid
posted on 24/10/12 at 10:57 PM Reply With Quote
You might get a better response if you post a couple of pictures up to show what you are asking.
Obviously not many people have experience of that particular chassis.
Padstar
posted on 27/10/12 at 11:35 AM Reply With Quote
Fair point. Here we go.
Layout drawing is as bellow showing LR13 being longer than LR14 resulting in the engine mount location being closer t the front.
Cutting details show it the opposite way round resulting in teh engine mount being located further back.
I would have thought the cutting details would be the one to go from rather than a 3D layout but before i go welding it in can someone confirm what way round it should go. Even if you have not used the Vodou design for your chasis, the mounting pints to all chasis should be the same?
Right now it is a very simple job to swap them round but knowing my luck if i dont check then i will end up with a major job of relocating further down the line..
Chippy
posted on 27/10/12 at 02:29 PM Reply With Quote
If I was doing that, I would just leave those two pieces off untill the remainder of the chassis had been completed. Then it would be a simple job to offer up the engine and gearbox to see where it all falls into place, then your sure of them being in the correct orientation. Just my 2d's worth. HTH Ray
