Author: Subject: Master cylinders
theduck
posted on 11/6/12 at 06:43 PM Reply With Quote
Master cylinders
Me again!
Currently have a sierra servo assisted master cylinder but the seals are knackered, so needs replacing. The original plan was to go with the sierra unit as I had it, see how it goes and either keep it, change to a none assisted single item or change to dual cylinders as I saw fit having driven it. Don't have that luxury now though so looking for advice on what I should be doing.
So I need your advice on what to do, as I see it my options are:
1) replace like for like
2) change to a none assisted cylinder (VW?)
3) change to dual cylinders
What I'm not sure in is what I need for options 2 and 3, what works involved and how much it will cost.
All advice appreciated.
theconrodkid
posted on 11/6/12 at 07:19 PM Reply With Quote
get one from a FIAT 124/127 from this company,i put one on my MK and it improved the brakes 100% tho it did require wome adaptation
who cares who wins
pass the pork pies
adithorp
posted on 11/6/12 at 07:25 PM Reply With Quote
Easiest swap for better braking is to go to a non-servo Mk1/2 Fiesta master cylinder. It's virtually a streight swap with the Sierra cylinder and will give much better feel.
Laptoprob on here did it this winter and is very happy with the results. Ask him the specifics via u2u.
http://jpsc.org.uk/forum/
paulf
posted on 11/6/12 at 08:57 PM Reply With Quote
Is this a slightly smaller bore than the Sierra one?.Although my car stops ok it would be good to have a slightly lighter pedal with a bit more feel. As far as I am aware there are 2 types of sierra master cylinder that are not interchangeable, mine is the cast version and there is also a more tubular looking one that has a different mounting flange with the holes in a different position, so have not got around to finding a compatible replacement yet.
Paul
laptoprob
posted on 12/6/12 at 07:05 AM Reply With Quote
FORD FIESTA MK1 NEW GIRLING BRAKE MASTER CYLINDER 1976-83 NON SERVO | eBay
Paid about 30 quid for mine from memory.
Vast difference from the Sierra version.
PREVIOUS THREAD
Pedal used to be rock hard with no-feel to it.
Now its very progressive.
Thanks to Adi
jps
posted on 10/9/13 at 02:37 PM Reply With Quote
Thread resurrection... is this the appropriate Mk1 Fiesta part?
FORD FIESTA MK1 BRAKE MASTER CYLINDER ATE UNUSED FINIS CODE 6067715
laptoprob
posted on 10/9/13 at 08:32 PM Reply With Quote
Yes that looks very much like it but doesnt have the push rod with it as mine did.
http://www.youtube.com/watch?v=ajlF4nWJtGA
40inches
posted on 11/9/13 at 08:28 AM Reply With Quote
That's the one, works fine. Same guy keeps putting them up in batches http://www.locostbuilders.co.uk/viewthread.php?tid=183420
jps
posted on 13/9/13 at 02:56 PM Reply With Quote
ok - it's arrived in the post (without a pushrod -as noted above) - and it has 6 outlets on it. I'm assuming that the top two are for a reservoir - any clues on how the other 4 (two on the side / two pointing towards the floor) should be configured - or where I look for that info?!
40inches
posted on 13/9/13 at 03:17 PM Reply With Quote
They are marked P and S, P (primary) ports are for the front brakes, and S (secondary) ports are for the rear.
I used the 10mm S port for the rear brakes, and blanked the 12mm port off.
If you bought the one in your ebay link, the outlets are opposite each other, on the sides, non point down.
[Edited on 13-9-13 by 40inches]
