mkeats02
posted on 1/7/12 at 03:47 PM |
Brake Pipe Damaged
While working on the car this afternoon I was drilling a hole and stupidly forget the brake pipe that runs down the tunnel was on the other side of
the panel, I have nicked the pipe with the drill bit, I also went through a wire but have repaired this (I should never have done any work on the car
this afternoon).
There is no hole in the brake pipe but there is some damage.
I am guessing I need to drill out all the rivets and buy and fit a new brake pipe down the tunnel as the pressure resistive strength of the brake pipe
will now be compromised.
Mike
HowardB
posted on 1/7/12 at 03:56 PM |
you already know the answer,...
Howard
myke pocock
posted on 1/7/12 at 03:57 PM |
YES, YES, YES!!! Dont take any chance with brakes. Dont matter what the cost or the inconvenience!
big_wasa
posted on 1/7/12 at 04:11 PM |
We all have days like that, more work left to do than when you started.
Best to just walk away.
Mr C
posted on 1/7/12 at 05:18 PM |
What about cutting out the damaged section and putting in a straight joiner?
Girl walks into a bar and asks for a double entendre, so the barman gave her one
posted on 1/7/12 at 05:25 PM |
Exactly what I would do but of course it depends on access.
mkeats02
posted on 1/7/12 at 08:44 PM |
As I thought, I think I'll start the pain staking process of starting to remove it all tomorrow evening.
