Author: Subject: Either alcohol or WD-40 oil damaged my gel coat
Alez
posted on 21/8/12 at 10:52 AM Reply With Quote
A while ago I used both of these while trying to remove double sided tape from the bodywork. One of these substances made the gel coat very soft and it actually peeled a little before I realized this had happened.
I cleaned everything dry and left the car alone hoping that the get coat would get hard again, which it did.
I need to know which of the two caused this because I need to remove some more of this tape again, and it would be good to use something more effective than just water.
Alex
Confused but excited.
posted on 21/8/12 at 10:58 AM Reply With Quote
IIRC that's why they banned fibreglas fuel tanks years ago. The alcohol that they used to put in the fuel made the tanks go like rubber bags. Not a happy situation on a motor bike.
PS Nitromors does the same.
[Edited on 21/8/12 by Confused but excited.]
loggyboy
posted on 21/8/12 at 11:03 AM Reply With Quote
Could it have been the glue in the tape that damaged it?
Mistral Motorsport
Mr Whippy
never had issues with wd40 on grp or any resins
use hot water from the kettle to remove stickers
richardh
posted on 21/8/12 at 11:13 AM Reply With Quote
i used a heat gun on LOW setting and then used a rag dampened with white spirit on mine and it worked ok for me.
Time for a change!
Alez
posted on 21/8/12 at 11:20 AM Reply With Quote
Thanks everyone for all the useful information.
I'm afraid not. The damage happened at a front lip where the liquid dripped and not where the glue was.
chillis
posted on 21/8/12 at 12:05 PM Reply With Quote
I would think it unlikely that wd40 would do that as its an oil.
I have used brake cleaner on GRP without issues but Acetone (which is used to clean GRP lay up tools) will soften the gel coat as you have described. Don't know what meths or ethanol would do but I suspect ethanol (whick is now in petrol) would soften both polyester and epoxy resins.
Would help to know what alcohol you used.
Alez
posted on 21/8/12 at 12:37 PM Reply With Quote
Thanks. I used the alcohol that's normally used to clean a wound, I don't know the proper name for it.
twybrow
posted on 21/8/12 at 01:21 PM Reply With Quote
Acetone should not affect cured polyester gelcoat... It is used routinely to clean moulds etc, and they do not dissolve! for a cheap source of acetone, try the Mrs' nail varnish remover. I dont know the forumlation of WD40, but I would suspect that to be more likely than the alcohol....
Did you leave it to soak? Ie was this liquid left on the surface for a long time? I ask, as any alcohol should have evaporated rather quickly.
Alez
posted on 21/8/12 at 01:33 PM Reply With Quote
It remained wet for say 20 min or so while I was trying to remove the glue, then I realized what had happened and cleaned it dry. I suppose the amount was enough that it wouldn't evaporate so quickly.
Alez
posted on 21/8/12 at 04:57 PM Reply With Quote
I don't have a mains plug nearby, so I can't use a heat gun / hair drier... I've now tried hot water and the glue was extremely difficult to remove, so I switched to WD-40 oil again, but used a very small amount. This has worked really well, with no damage whatsoever and has made the glue extremely easy to remove by rubbing with a cloth. I've then removed the oil as thoroughly as possible using a different cloth, then washed with warm water and soap. Therefore my bodywork is now ready for the new number plates
Thanks all!
[Edited on 21/8/12 by Alez]
